Iba bb 1500
But when you doing the BB, you will find you need to move right along. Someone lagging in the group, or an additional bike which means possibly a mechanical issue just doubled… I am not so sure two or more for a BB is such a good idea.
For the BBG, I do not support doing this any other way than solo. The timing has got to be impeccable. The refueling comes down to a science practically. Any little blip is going to blow the BBG. As I understand it, each time you add a person to a LDR, you start to increase mechanical issues and a natural slowing down of the ride.
GOLD rides cannot have a hitch. They are WICKED FUN!!!!!!!!! But the timing and routing has to be impeccable.
I certainly wish you luck no matter what you decide to do. I would be behind you supporting you 100%.
IMHO,
BC7
Have you checked out the A.O.W.? (Archive Of Wisdom.) If not, I will be happy to link you to it.
Your line of thinking is bull's eye perfect. Also you want to stay on the super slab the best you can. And do not go down one side of it and then up the other. That is strongly discouraged. More of a triangle will work very well.
And of course, always run a little longer mileage wise. If you are doing a thousand miles, you want to make sure you do over 1000 miles. IBA takes checking your route very seriously. If you use a mapping system that shows you went a thousand miles and IBA checks your route and comes up with 999 miles, you will not be getting the SS. Know what I mean? So you want to make sure you run another longer than whatever your goal is.
Man this is so much fun, as I am sharing this with you I am getting all kinds of excited
When I did mine, I was on a ZX12R...geared for 221. (But, I never went over 170.) Just lumbering along...
You can ask them. They are good in getting back to people.
I got my BB and BBG at the same time.
To go right to the BBG to me is a mistake. At least have an SS under your belt 1st I.M.H.O.
The "G" in BBG is pretty serious business. If one does not know how to properly stay nourished and have their stops down properly and have their root proper, getting the "G" is going to be one major event.
For those who have their SS and BB, the "G" is still very admirable.
But again, IMHO going straight to the "G" in my opinion is highly undesirable and flirting with danger. <-- Yes, I would go that far.
I would suggest to whomever, walk before you run.
Lastly, it is better to have several smaller successes before you reach for the "Gold".
When I was setting up the BB, a friend said why not go for the BBG?<-- That did not even occur to me. So I went for the BBG and got the BB on the way.
BOOD point mtgriz. The IBA website would have the updated info. Honestly, I have not checked their regulations for several years. Good point.
