new 2015 cvo streetglide
Old Aug 19, 2015 | 11:36 AM
myanoch's Avatar
myanoch
Default new 2015 cvo streetglide
Does the cvo have a stage one tune in it from the factory
Is the SERT stage one tune the same as factory for this bike
Can't look at stock tune in bike now unless at dealer
Old Aug 19, 2015 | 02:27 PM
SlowRain's Avatar
SlowRain
A stage one tune? No. It is tuned for the system it is sold with.
CVO's come with a high flow air filter, but the factory exhausts have cats in the heads. CVO's also come with 255 cams. It is tuned accordingly. So..if you were to do a "stage one" you would have to do the same thing you would do for a non-CVO bike...pull and change out the exhaust, you won't need a high flow air filter since that is already on the bike. You need a tuner, and a dyno run unless you are using something like an FPS, Power Commander or the like.
Old Aug 19, 2015 | 05:36 PM
myanoch's Avatar
myanoch
Well I have done SEPT tunes on my last two SG
none had a tune likeon this one
617SEP204.dto
states 110 ci
SE air cleaner
SE exhaust
255 cams
That what my bike has from Harley
I was trying to decide to go to stage 2 because I have that tune as a base
probably already
No big deal I will start there and tune from that base
I wish you can look at what bike came with
I believe cant look at original tune
The 103 does not match any one like this
Had to tune from beginning
Allen_lemessurier@yahoo.com
Milwaukee Eight (M8)
May 9, 2017 09:23 AM
PistolPete83
Screamin Eagle CVO Models
Apr 29, 2017 03:34 PM
ogschile
The Dyno Room
Feb 4, 2017 05:35 AM
oneloudz71
Engine Mechanical Topics
39
Dec 4, 2015 07:14 AM
fatbobbranden
Jan 28, 2009 10:18 AM
