The bike is basically stock (bought used with 1262 miles - assuming stock). I added Fuelmoto headpipe (Jackpot Super Duals & Crossover), and ThunderMax, stock mufflers. Terrible starting issues since ThunderMax install, but usually only first start of the day. After fighting to get it started it runs pretty well. Have done all the suggested things - new battery, clean / dielectric grease connectors (throttle body), adjust both initial and cranking fuel, even loaded modified map from ThunderMax support. Now have experienced limp mode since install of modified map.
The question is, has anyone successfully ran this setup or similar with ThunderMax? Do I have a faulty module or have they just not been able to get it right with the Rushmore's?
i had hard hot start issues with 2014 limited with thunder-max and rush pipes . eventually thunder-max found their problem and corrected it with new downloads.
u may have better luck in rushmore section or tuning issues sections. I think Thundermax will have a solution keep bugging them and send them your maps to correct.
