Boom Box 6.5 GT Maps update
Old Apr 30, 2019 | 12:34 PM
John 105's Avatar
John 105
Stage III
Originally Posted by zubaugh
I have a 2018 CVO Limited. I would like to see what my NAV version is compared to what is available. Since there are only 3 free updates in 5 years can I wait a year or more to register or does the 5 year clock start with my year model? Seems like there is no reason to update the maps now. Also can I update dealerships and POI without using one of the free updates? Can't seem to get past the log in/register to find current versions
H-D provides free updates for System Software and Dealer POIs. The maps are what cost if you do not have an CVO
Old Apr 30, 2019 | 12:36 PM
John 105's Avatar
John 105
Stage III
You can update the System Software and Dealer POIs without impacting you 3 free map updates. I just updated the System software and Dealer POIs free for a 6.5 Boom Audio.
Old Dec 30, 2019 | 08:40 PM
stuart1270's Avatar
stuart1270
https://www.harley-davidson.com/gb/e...avigation.html
Version: 1.22.0.2 | Size: 842 MB
Date Released: January 16, 2019
Fixes
• Arrival time showed the current time after user deviated from a route.
• Next turn area displayed an arrow with the current street name.
• Special Alpha Jump characters were not displayed.
• The SMS (Short message service) repeat button wouldn’t read the message clearly if pressed multiple times before it has completed the readout.
• Audio paused after loading a ringtone.
• VR (Voice recognition) not working after an ignition cycle.
• Local media preset inconsistent between shutdowns.
• User was unable to search for preferred POI (Point of interest) after simulation sleep.
• Constant “Game Start” pop-ups.
• Presets from USB (Universal serial bus) drive 1 were still visible on USB drive 2 but not highlighted as available.
• Albums and artists heading were mismatched with list.
• AM (Amplitude modulation) radio presets not highlighted when USB was unplugged.
• Repeat button NOT enabled on first selection.
• Pre-cal reset did not delete trails.
• Accept screen appeared for less than 15s after exiting User Off mode.
• Saving or editing emergency number did not work.
• No SiriŽ pop-up displayed while saving an emergency number.
• Text was missing in the maneuvers list after switching to high contrast mode and then back.
• No initial Siri pop-up initiated.
• Cancel noise was heard when going from VR to Siri.
• Prompt Volume was not updated after changes in Feedback Settings.
• GPS (Global positioning system) entry changed W(O) to E in Spanish.
• WHIM (Wireless headset interface module) – Low battery pop-up was not shown for passenger headset.
• WHIM – Paired BluetoothŽ device name appeared as “Headset”.
• Repeat prompt was not working.
• SiriusXMŽ weather map did not maintain the default zoom level.
• User off mode enabled navigation prompts.
• VR conflict if Siri was launched from phone at the same time with the radio.
• Saved USB presets for drive 2 were replaced by drive 1 after an ignition cycle.
• USB saved as favorite was not highlighted after an ignition cycle.
• Distance to next action bar disappeared before route recalculation instead of being grayed out.
• “Navigation is not ready” displayed when initiating navigation command to “Find Next Gas Station” via VR.
• Various bug fixes
This update has a problem. Once updated you can't save locations on the gps.
Old Jan 4, 2020 | 02:00 PM
RichardH's Avatar
RichardH
My 2019 CVO has Map database NA-MY2019-1.
After calling Harley customer service they said the Nav map updates are not free for CVOs.
The software update & dealer database updates are free.
I believe some of the older CVOs did have free Nav map updates but not my 2019 CVO.
This is another thing Harley cut out to save $$.
If anyone finds a way to get free Nav map updates on their CVO please post.
According to the guide you download & install HDBoomBoxGTSToolbox-inst.exe on your computer.
https://harleydavidson.welcome.navie.../guide_en.html
After running the Toolbox you have to select Buy Content option & furnish your credit card.
5 - BUY UPDATES AND EXTRAS
  1. Log-in to Boom!™ Box GTS Toolbox and choose Buy Content on the HOME screen
  2. Select the map update by clicking on it that you wish to buy.
  3. Place your order by clicking on Buy xx USD.
  4. Enter your invoicing data and click on Next (If you have already purchased content in Boom!™ Box GTS Toolbox, then your address will be stored upfront. Issued invoices cannot be modified, therefore, carefully check your information before proceeding to payment.)
  5. Read the Terms and Conditions of Purchase and click on PAYMENT
  6. Choose the type of your credit/debit card and enter card information.
  7. After your payment has been processed, click on Install
  8. Select the content you wish to Install and press Install once again.
  9. Eject the USB flash drive, insert it into your vehicle’s head unit and upload the map update to your navigation system (see section 3. Navigation Data Synchronizing).
Old Jan 6, 2020 | 05:13 AM
flash1034's Avatar
flash1034
Thanks for the info.
Old Jan 8, 2020 | 08:43 PM
harleysteve's Avatar
harleysteve
Yes free CVO maps stopped from 2019 MY - only found out AFTER I bought the bike. However with the GTS systen from 2019 on you have Apple Play so can use Google maps or Waze
Old Jan 27, 2020 | 10:05 PM
RiderX's Avatar
RiderX
When you did this in the Boombox GTS Toolbox, did you get the option to purchase the CVO maps or did it just say MY20 for $149.95? If you login to https://naviextras.com and look for maps, they offer one for the CVO at $159.95 and another map, it has the same title except without the CVO, for $149.95. For me, in the Boombox GTS Toolbox, it only offers one option which says MY20. There is no option that says CVO.
I am wondering what the difference is between the CVO version of the MY20 maps is and the standard version of the MY20 maps. I am also wondering why the Boombox GTS Toolbox only offers one version which says MY20 for $149.95. Since the $149.95 price within the Boombox GTS Toolbox matches the cost of the non CVO version on the Naviextras.com website, I assume this version is the non CVO version.
I tried contacting Harley to ask these questions and they were basically clueless.
Old Jan 30, 2020 | 01:33 AM
flash1034's Avatar
flash1034
Excellent question. I was curious too.
Old Jan 31, 2020 | 12:46 AM
RiderX's Avatar
RiderX
I started a new thread about this and was finally able to get the answers to these questions. Here is an excerpt from my post. Here is a link to that thread so you can read it if you like - CVO Map Update Thread
I started on this journey because I wanted to make absolute certain that for the 2019 GTS radios that there is no difference in CVO vs. non CVO maps before spending $149.95. I spent a lot of time, both on the phone and through trial and error, trying to get the answer to this question before spending $149.95 on a map that did not contain all of the features designed for my CVO bike. I hope you find the information below helpful.
All GTS radio systems can no longer be updated using the NaviExtras Toolbox. They must be upgraded using the Harley Davidson Boombox GTS toolbox. They changed something in the way the fingerprint is created that makes it unreadable by the NaviExtras Toolbox. This is why no matter how many different USB devices I used or which computer I tried plugging them into, NaviExtras would not recognize them.
An 8 GB USB drive will no longer suffice. You will need a 16 GB USB device to complete the download and installation of the map software to your USB device. I used a 16 GB USB device and after the installation of the map update to the USB completed, there was close to 12 GB of data on the drive. Also, exFAT is now a supported file system to format your USB device. This is handy to use if you have a USB device over 32GB in size. There are ways using third party tools to format drives over 32GB with FAT32, but I digress.
The Boombox GTS Toolbox will only show a map update such as MY20 and no longer distinguish between CVO or non CVO versions of the map. I have been assured that although there is a difference between the CVO and the non CVO maps for bikes with non GTS radios, this is no longer the case for 2019 bikes with a GTS radio.
Keithhu
Milwaukee Eight (M8)
87
Aug 2, 2022 07:30 PM
Terryjft
Audio Systems
Sep 16, 2017 07:35 AM
Ohio HD Guy
Screamin Eagle CVO Models
13
Mar 26, 2016 07:06 PM
plongson
2014-2024 Touring Models
21
Jul 30, 2014 06:12 PM
