Does anyone know for sure if the Screaming Eagle Air Cleaner kit https://www.harley-davidson.com/stor...ir-cleaner-kit
has better air flow numbers than the stock air cleaner on the CVO Limited? Please don't tell me that the limiting factor is the Throttle Body. That only becomes true once you max out the stock throttle body's flow, up till then every little bit helps.
The Stock part number is 29400267.
It is very similar, just different materials then the K&N unit. I cant answer if it flows the same or not but it is a synthetic material that can be washed and reused, just not oiled like a K&N
i switched out my heavy breather for the ventilator just because i wanted to run lowers. i know that they say the ventilator will cost a few hp/tq over the hb, but my butt dyno doesn't feel it, so i'm okay with it.
