Leaking oil
I still hope to get 8 - 10k miles this year.
The heat on the rear cylinder doesn't help the situation, but is not the root cause. The new gasket part number does NOT solve this issue.
Can you say Extended Warranty?
I have a good feeling this wont be the last time I am going to have to deal with this SH*T !
Blues...is it related in anyway to the excessive pinion runout I've been hearing about?
I asked about that and they said $150.00 - $200.00 to check it and if it was bad they would pay it back. But they have no reason to check it, from what they say!
F**kers, Itwould be nice preventative matinance to just check it! They said if it messes up then they will fixvia warranty. What ever. I dont have $200.00 buck right now. Thanks for listening to me vent!
Almost every 110 engine has leaked on the rear cylinder, and sometimes the front too, but it typically does not show itself until you have 3-6K on the bike. Generally starts with a slight "weep" on the rear headgasket, near the exhaust flange, then shows itself further at the base of the rear cylinder with puddles of oil. Oil is migrating down the cylinder studs, pooling at the base, then coming out around the O-ring. I know some who are on their second and third set of gaskets, have had cylinders replaced, and the leak comes back after approx the same amount of mileage. All covered under warranty, but plenty of down time. HD knows of the problem, but has yet to come up with a fix after over a year of leaks. Could be the fitment of the cylinders to the cases too. Nobody knows yet.
Not trying to rain on your parade, but this is something to really watch on the 110's.
I would make them give me a loaner after the first attempt, and I would NOT let them take 3 weeks to do the job either. Whether HD will admit it or not, they know about these issues, and if you raise enough hell, they will get the parts there and the dealer can get off their butt and fix your 35K bike.
The runout problem causes other stuff, and not every bike has that problem, but instead of HD owning up and checking the bikes, they let the customer have problems first, THEN do something.
The average HD rider only puts 5K miles on a year, so they hope the warranty runs out before these problems show up.
That is the same exact way my leak started!
