VVT on 2023 CVOs?
Old Mar 17, 2023 | 09:39 AM
wildandfree's Avatar
wildandfree
Default VVT on 2023 CVOs?
Did you see the leaked "potential" 2023 CVO pictures?
I was made aware through a couple of YouTube videos released yesterday. While most of the attention was put on the new RG and SG fairings, 121ci engine, and inverted front suspension, I was more interested in the changes to the cam cover, and engine case, including the transmission. Zoom in on the cam cover. See the "VVT"?
Could it be that the next generation of M8s will have variable valve timing like the Rev Max engines? I hope so, because I love the powerband on my Pan America. It's exciting to ride when the Rev Max gets its second wind.
Old Mar 17, 2023 | 09:44 AM
FLASH1970's Avatar
FLASH1970
https://www.hdforums.com/forum/gener...oad-glide.html
Old Mar 17, 2023 | 09:59 AM
wildandfree
Thanks, but my post is specifically about the potential of having VVT on the next gen of CVOs. I'm not getting into the train wreck in the post you shared. It's going off the rails.
Old Mar 17, 2023 | 10:03 AM
rigidthumper's Avatar
rigidthumper
Well, it says "VVT" on the cam cover, and the factory patented it in 2019, so...
Old Mar 17, 2023 | 12:32 PM
kojak's Avatar
kojak
https://www.motorcycle.com/new-model...e-has-vvt.html
Old Mar 17, 2023 | 12:46 PM
downzero's Avatar
downzero
FWIW, I think this is sophistication that I would not want, as one of the things I like most about conventional Harley-Davidson motorcycles is the simplicity of air cooled engines and the torque the large displacement produces.
VVT is not going to make a Milwaukee 8 feel anything like your Pan American. A higher revving water cooled motorcycle is a totally different animal than a conventional air cooled Harley-Davidson. VVT may be a way to extend the power band a little bit one direction or another based on how it is used, but it isn't going to change the characteristics of a torquey low revving engine into one like your water cooled bike.
I don't know if you've ever ridden a V-Rod but it is totally unlike riding a conventional air cooled Harley-Davidson, but once wound up, it definitely has the horsepower. The feel is totally different, however.
Old Mar 17, 2023 | 03:29 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
VVT has its power benefits, but it also has emissions benefits, which I think is HD is exploiting to extend the use of air-cooled engines a few more years.
Old Mar 18, 2023 | 08:38 AM
rigidthumper
Bingo- emissions compliance keeps the MOCO producing/selling vehicles. If we get more power as a side effect, I'm OK with that. Gonna be more $$$, but you can't take it with you when you leave this realm...
Old Mar 18, 2023 | 09:47 AM
stratplexi's Avatar
stratplexi
This only makes sense…on a lot of fronts. Not saying I want one but from a business perspective things are unfolding and lining up. As mentioned, the patents exist and this type of change can be rolled out on some CVO models before going across the entire product line. They have a history of doing this. More power, lower emissions, and still a big air/oil cooled V-twin with the sound everyone associates with a Harley. I think it will be a success.
Old Mar 18, 2023 | 11:09 AM
FLSTFI Dave's Avatar
FLSTFI Dave
The M8 will never be a high raving motor. I do however believe the VVT will help keep it emissions compliant longer, and will let it have a better power curve in its current RPM range.
