2009 cvo ultra classic cross threaded spark plug
Old Sep 23, 2009 | 07:23 PM
Paul Pisano's Avatar
Paul Pisano
6th Gear
Default 2009 cvo ultra classic cross threaded spark plug
The rear cylinder spark plug may be cross threaded on my 2009 CVO ultra. The spark plug move about a quarter of a turn and stopped. Rather than take it off, the tech screwed it back on, then called me. Has any one experienced a similar problem with a cross threaded spark plug, or something similar? Appreciate any feedback. Paul
Old Sep 28, 2009 | 05:16 PM
raymattheus@yahoo.com's Avatar
2nd Gear
Default over heating
I have a 2010 ultra with 2000 miles and the rear plug seized into the head from heat. When dealer removed plug the head had melted to the plug threads. Service department said it was crossthreaded. ( that is a lie ) update me
Old Sep 30, 2009 | 08:49 AM
lowleveldriver's Avatar
lowleveldriver
I hope the don't try to say you did it
Old Oct 1, 2009 | 01:02 PM
Chris in NC's Avatar
Chris in NC
6th Gear
Originally Posted by Paul Pisano
"... the tech screwed it back on,..."
Regardless, it's on the dealer.. If they push back, call a lawyer.
Old Oct 3, 2009 | 12:48 PM
boom23's Avatar
boom23
I would make sure that you get a replacement new head. They might try to tell you that it's OK or to try to fix it.
Old Oct 4, 2009 | 06:48 PM
Paul Pisano
6th Gear
Thanks for the advice...I'm taking it in on Tues. I'll let all know the outcome tues night
Old Oct 4, 2009 | 09:28 PM
emwolb's Avatar
emwolb
and that's the reason i always use anti seize on spark plug threads. damm, that's gotta suck that they are trying to explain the problem away. don't let them helicoil the head.
Old Oct 10, 2009 | 10:09 PM
Shovelhead Bob's Avatar
Shovelhead Bob
FWIW.... I have seen thus far, 3 09/10 bikes that the plugs were galled in the heads....
If the plug is removed slowly, and back and forth SLOWLY, the threads can be saved, but the head still needs to be removed for a proper repair...
Seems like the anti-sieze is not being put on correctly, or not at all...
Makes me wonder if the "Lean Manufacturing Process" is being carried a little too far...
Old Oct 10, 2009 | 10:13 PM
1931jamesw's Avatar
1931jamesw
I found this thread that was posted today. https://www.hdforums.com/forum/hacke...m-with-tg.html
Old Oct 11, 2009 | 06:44 PM
2nd Gear
Default harley
Paul
Did you pull the back plug,The one on my 2010 head was welded to the plug from getting so HOT
raymattheus@yhoo.com
