Trouble in Paradise
Old Nov 12, 2015 | 11:39 AM
Racepres's Avatar
Racepres
Originally Posted by 74shovel
I have had the very same thing happen to me. Behind the head light there is a connector that connects the white wire from the frame harness to the white wire on that goes to the ignition starter on the right handle bar. When you lose connection you lose power to ignition and starter.
Mine has failed me twice the first time it was burnt from over heating the second it lost conductivity momentarily.
I soldered and heat shrunk it this last time.
Actually the white wire comes from the right housing Kill Switch.
The Grey wire goes to the housing from the keyswitch...Stock.
Just to clarify.
Old Nov 12, 2015 | 05:52 PM
74shovel's Avatar
74shovel
Just to clarify.
That means I don't have it fixed, crap. I bet it is the kill switch then
Old Nov 12, 2015 | 07:45 PM
Racepres's Avatar
Racepres
If it is aftermarket? Probably...if O.E. only maybe. Most common is pinched wire when assembling the [handlebar] switch housing sometimes shorting to ground, sometimes cutting the wire inside the Insulation.
Some care, and some bit of Dexterity are required...along with Patience....
SugsPa
Jun 2, 2017 08:21 AM
softail99custom
EVO
Jul 12, 2012 07:24 PM
MJR
Sep 17, 2011 09:10 AM
laythss
EVO
Aug 9, 2010 09:59 PM
stevepacman
May 24, 2008 12:24 PM
