ignition question
Old Apr 6, 2017 | 04:46 PM
lt56's Avatar
lt56
Default ignition question
nothing happening when i hit the start button on my 82 FXWG.
looks as though all the connections are ok. i get 12 volts to the relay when i push the button, but no juice coming out. i bought a new relay and have the same results. i'm wondering if this could be the solenoid? can i put a jumper from the battery to the (center post, the one that comes from the relay) wire on the solenoid to see if it turns it over?
Old Apr 6, 2017 | 08:49 PM
lt56's Avatar
lt56
not sure how to delete this thread, but it was a bad ground from the relay.......
Old Apr 6, 2017 | 08:54 PM
TwiZted Biker's Avatar
TwiZted Biker
Your fine it'll die on it's own and congrats of finding the trouble. Word of advice on shovels and your issue , check and clean ALL the cable connections and the frame ground in particular. Half or better the elec. problems I see come back to grounding issues or bad crimps.
bluberryjenkins
Electrical/Lighting/Alarm
Jan 18, 2015 08:26 PM
goallight
Jun 29, 2013 11:48 PM
tidefan60
Aug 7, 2010 03:25 PM
kelton3
Mar 31, 2008 10:45 AM
jgcable
Sep 4, 2007 06:58 PM
