Wiring question
Old May 5, 2017 | 11:15 AM
theCoach's Avatar
theCoach
Default Wiring question
Getting started on rewiring my 75 FXE, using a new main harness only. I'm getting away from the handlebar starter switch-it was always a weak link in the system, so only the front brake light switch and the taillight will have to be added (no taillight or handlebar wires with the harness) wondering if it would be considered an upgrade to modify the circuit breakers to fuses. Any advantages to fuses?
Old May 5, 2017 | 02:53 PM
Aquadan005's Avatar
Aquadan005
Besides cost, I don't see any advantage. Fuses need to be replaced when they blow, circuit breakers reset themselves.
Old May 5, 2017 | 03:13 PM
adm's Avatar
adm
You could always go solid state and eliminate all of the relays, circuit breakers, fuses and all that gubbins. You'll end up with much simpler and more reliable wiring loom:
https://motogadget.com/shop/en/m-uni...sicherung.html
This is how I am rewiring my shovel.
lsdylanc66
Shovelhead
Apr 14, 2017 07:35 PM
LouEyez
Jun 11, 2011 11:46 AM
65_glide
Panhead
Aug 9, 2010 10:53 AM
Gnight
Mar 26, 2009 09:44 AM
1986FXST
Jun 4, 2008 03:31 PM
