My first agm battery,what kind of battery tender should i use.Just went out to fire her up battery was down
Deltran does make a specific tender for AGM batteries that will also work on conventional lead acid batteries.
Amazon sells them and has an excellent product description provided by Deltran that explains this charger's
differences from standard chargers.
Read it and decide for yourself - opinions vary on this subject. Regardless, if I'm not riding regularly and
have my bike on a tender I also use 110 volt AC timer set for 30 minutes each day.
Glad you got it sorted. My 13 Lo has had 3 HD batteries. The one it came with lasted 2 years. The next 2 lasted about 6 months each.
I'm gob-smacked your original lasted this long. Problem with HD is they're expensive as hell and there's no date on them so you have no idea how long they've been sitting on the shelf.
have tried multiple Brands of AGM... have come to the conclusion that a Charger intended for AGM Batteries is best, and I Buy inexpensive Batteries from Chrome Battery, they last about 2 or 3 Years... no tender, tho, and no Timed Charger... The Biggest Killer of lead acid Batteries, is OverCharging...
