Electronic single fire ignition issue
Old Jul 27, 2018 | 12:59 PM
Jaxryde's Avatar
Jaxryde
Default Electronic single fire ignition issue
80 Strocker with single fire ignition starts when cold. After running and warming up motor won’t restart until sitting for about 1/2 hour. It backfires and pops but won’t start. Once cooled down she start right up and runs strong. I’m thinking heat is the cause. The nose cone is hot to the touch.
Old Jul 27, 2018 | 01:40 PM
fergerburger's Avatar
fergerburger
which single fire - the Dyna S induction that uses a 5 ohm coil or the genuine electronic set like Ultima or Crane Hi-4 (uses a 3 ohm coil)? If you use a 3 ohm coil with the Dyna S single fire you'll overheat the coil and it will crap out - your symptoms sound like an intake leak - at least - you are describing what is a common symptom of a leak at the band or O-ring seal in a shovel
Old Jul 28, 2018 | 12:10 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Yea, need exact make and model of ignition...
Old Jul 28, 2018 | 03:38 PM
Jaxryde's Avatar
Jaxryde
Default Comp U Fire HDE 3
i have had this ignition in the bike for 25 years since the engine build. Matches duel coils. I’m leaning towards and intake manifold leak.
Steen
Feb 5, 2016 05:44 PM
shizzomynizzo
Shovelhead
Jun 29, 2014 12:07 AM
Seanrlynchh
Apr 13, 2013 06:15 PM
TOMMY M
Sep 3, 2009 12:57 AM
92classic
EVO
Mar 29, 2008 08:54 PM
