Solenoid question
Old Jul 4, 2019 | 06:31 PM
doc308's Avatar
doc308
Default Solenoid question
I had to take the transmission out of my '77 for a rebuild and now it's time to reassemble everything. This is my first time working on an electric start bike and am unfamiliar with some details. So... I bolted up the solenoid to the case and everything seems to be lining up and working ( manually) as it should with the starter shaft. However, I noticed that there is a gap--apprx 'ly 1/16" between the edge of the solenoid body and the primary surface. Is this normal or did I assemble something off kilter? I don't recall if it was like that when I disassembled it.
Old Jul 4, 2019 | 06:47 PM
johnjzjz's Avatar
johnjzjz
its held by 2 bolts at one side and a spacer - some bend out more then others
you should post a picture to be on the same page
Old Jul 4, 2019 | 07:09 PM
doc308's Avatar
doc308
Old Jul 4, 2019 | 07:15 PM
doc308's Avatar
doc308
I have one more question re: the wiring on the solenoid: I know that the top, longer stud goes to the battery cable and that the lower shorter stud is wired straight to the starter. The 2 wires coming from the relay: the small connector obviously goes to the small middle stud. The other wire , with the large eyelet goes to which post--the battery or the starter post?
Old Jul 4, 2019 | 07:19 PM
Bumpandrun's Avatar
Bumpandrun
Battery.
Old Jul 4, 2019 | 07:21 PM
TwiZted Biker's Avatar
TwiZted Biker
That's a very good fit compared to a lot I see, aligns nice and straight too not cocked to one side.
Old Jul 4, 2019 | 07:22 PM
glidein wide's Avatar
glidein wide
The rubber boot has a flange that seals the solenoid on the outside, along with a foam ring. The boot install from the outside and push into the hole.
Old Jul 4, 2019 | 07:27 PM
doc308's Avatar
doc308
Thank you, Gents--much appreciated.
PBL
Engine Mechanical Topics
Jun 19, 2018 10:02 PM
portaman03
Shovelhead
Aug 16, 2013 10:36 PM
Garry81FXB
Shovelhead
21
Mar 27, 2013 02:57 PM
paul d
EVO
18
Aug 30, 2010 09:15 AM
harleybob
Aug 5, 2006 09:59 PM
