Baker 4 speed?
on the 71 ive had a 25 front sprocket, pretty sure the drum is a 51. That ratio has been enough OD for solo riding, so im having trouble justifying a 6 speed. But the baker only comes with 23/24?
Open primary so clearance isn't an issue.
Is there any competition?
wheres the best price for a Baker?
Baker has been having issues lately...might want to do some research before ordering...
https://www.hdforums.com/forum/touri...ng-issues.html
https://www.hdforums.com/forum/prima...ait-times.html
Since you are running an open primary...you could pick up a used 5 speed...all you would need is a mounting plate...
Use an early one with tapered shaft to use your present clutch...or get a later splined one if you want to upgrade the clutch...
IMO it will shift better than any 4 speed (baker included)...and you won't have to deal with the normal 4 speed mainshaft leak
You can also change to the superior ball and ramp clutch release...or use the 4 speed style if you are hard headed...
depending on the options you chose you could do it for 1/3 the price of a nice 4 speed...and the lower 1st gear and closer ratio will make it more fun to ride...
https://www.ebay.com/i/123216403140?...RoCbycQAvD_BwE
Rarely hear Technology borrowed from the XL touted as a Breakthrough.....They do work good tho... been working on XL's since the Early '70's.... LOL
Oddly, I have had Zero Problems with the old 4-speed design "Throw out"... but, been "working with them" for a very long time...
The release fingers fail without warning...and have been responsible for many "Harley parties " on the side of the road..
I did not know that the '86 Softail was the Only 5 speed that would work??? Interesting...
or is that the first one that won't work???
nope... just the only year the 4 speed type clutch release mechanism came on a 5 speed softail trans....
Came on tons of touring bikes and FXRs...Any year evo softail 5 speed trans can be made to work in a 4 speed frame..
and I much Prefer the old 4-speed Clutch to the damnable 85 thru??? I forget... but I hate that tapered shaft abortion vs a real clutch..
That "Can be made to Work" can be a stickler at times as well...
A Sportster can be converted to left side Drive too
http://www.amraonline.com/BikePics/PsuedoQS.jpg
LOL .... Sorry... couldn't resist!!!
