Hard Start When Warm
Old Aug 27, 2019 | 09:55 AM
Monteman1971's Avatar
Monteman1971
Originally Posted by hscic
If it looks lean, then perhaps intake leak as John suggested. Does your bike run like crap when throttling i.e. hesitation, popping?.
It runs surprisingly well. Starts right up, accelerates crisp, shifts well and minimal popping. It does have those straight pipes with no baffles so I attribute the occasional pop to them but nothing bad at all.
I'm going to check for leaks this weekend as well as the float level.
Thanks for all the suggestions
Steve
Old Aug 28, 2019 | 09:02 AM
Racepres's Avatar
Racepres
And...What happened when you simply tried the Enricher when Hot Starting???
Old Aug 28, 2019 | 03:42 PM
Monteman1971
Haven't had a chance to try that just yet.... this weekend.
Thanks, Steve
Old Sep 23, 2019 | 07:28 AM
Monteman1971
Update...Opened the inspection cover to find that someone replaced the points with a Crane Cams ignition. Three dials to adjust: Spark Advance, Rev Limit and Rear Cylinder....retarded an 1/8 turn on the spark advance and now the bike starts no issue when hot.
Thanks for every ones help.
Steve
Old Sep 23, 2019 | 01:35 PM
johnjzjz's Avatar
johnjzjz
the kind of up front info that is real helpful - guessing what's wrong ends in this sucks when you read you never checked anything
Old Sep 23, 2019 | 02:38 PM
Monteman1971
I'm sorry if I imposition you in any way. As I stated in my original post that this problem started after I changed the float and I'm new to shovel heads so the two issues are really not related although it seemed so at the start. Why it started hot before the float but did not after, was the mystery so I was looking to see if anyone had experienced this. It was my basic knowledge of engines that made me think timing but again, I don't have the manual (not my bike) so I wasn't even sure where to start.
And in re-reading this thread, no one said to check the points/timing...did that on my own.
But I thank everyone for bearing with me on my learning curve and appreciate the point in the right direction and where to start looking.
Steve
Old Sep 23, 2019 | 03:48 PM
johnjzjz's Avatar
johnjzjz
I message board thing should exist - explaining what the correct way to engage about an issue
that was really not directed at you it was general statement - and I should have said that - as it is all the time a lack of info about what was done before this happened - on and on and on
Old Sep 23, 2019 | 07:26 PM
Monteman1971
I think I did clearly state the problem (changed the float and then was hard starting when hot). At that time nothing else was changed and that's why I was looking to see if any one else had encountered this issue. Many including yourself came up with good ideas for me to check and when those didn't t work I looked further into other areas. But I wasn't going to start tearing into other parts of the bike that at the time seemed unrelated.
So so am I still missing "the correct way to engage about an issue? Isn't that part of the purpose of these boards? Have an odd problem and looking to see if any one else has experienced it?
korben.smith@yahoo.com
Jul 12, 2018 01:07 PM
danny1975
Shovelhead
24
Sep 10, 2014 09:47 PM
chuckbrunson
General Topics/Tech Tips
Aug 28, 2010 08:13 AM
83perry
Mar 7, 2010 05:16 PM
deonc81
Shovelhead
Jun 7, 2009 06:53 AM
