Anyone recognize this spring?
Old Jan 4, 2021 | 10:30 AM
chopper_man's Avatar
chopper_man
Default Anyone recognize this spring?
In the middle of my rebuild of my chopper and found a spring on the ground, chassis based off 74 FX, engine 79 FL 1200. Found this spring on the ground and do not recognize it.
Things that have been done to give you an idea of what I've been in to.
Full top end, front and rear masters rebuilt. Outter primary off, clutches cleaned reinstalled. It has an S&S oil pump on it and I did replace the check ball, double checked there, that's a straight spring. Solid lifters which never came out or appart. I did not go in to the nose cone or had inner primary off.
This spring is clean, I mean super clean, zero oil on it, zero rust, almost like it's brand new. I did buy a Cometic full gasket set for it so it's possible it came out of there but don't see it in the list.
Picture of the spring and some of the bike.
Thanks,
-Brian
Old Jan 4, 2021 | 10:58 AM
470004's Avatar
470004
A cool early HD's springer extended front end.
Old Jan 4, 2021 | 11:45 AM
Lowoilpressure's Avatar
Lowoilpressure
Dude I don’t know.
I walked into my shop last week and almost tripped over a big greasy black bolt in the middle of the floor. Problem is I haven’t worked on my bike for a month and I honestly don’t understand where it came from and what it’s for. But I’m being totally honest, it was in the middle of the floor. Like an angel, or the devil put it there. And I’m still a little freaked out.
Tom
Old Jan 4, 2021 | 11:54 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Almost looks like a plunger spring for the piston in a brake master cylinder. Not sure though. Did you get a Master cylinder rebuild kit?
Old Jan 4, 2021 | 11:55 AM
Jackie Paper's Avatar
Jackie Paper
It's off your lawn and garden hand clipper
Old Jan 4, 2021 | 12:24 PM
chopper_man
I did and already checked both kits (I save old parts for a while), front and rear accounted for. Both plunger springs are cone shaped and longer. Thank you tho.
Lowoilpressure
Here’s a similar spring from my wire cutters.
Old Jan 4, 2021 | 12:25 PM
chopper_man
Very well may be! Never seen a douple tapered spring on any HD.
Old Jan 4, 2021 | 12:26 PM
chopper_man
Holy **** that's it!!! I just went out and checked. I did put new ends on my coils! You the man, thank you!
Old Jan 4, 2021 | 12:28 PM
RHPAW's Avatar
RHPAW
It's not mine. Hope this helps.
But seriously...plunger on the solenoid?
