Differences between FXS and FXE
Old Aug 30, 2022 | 07:06 AM
  #71
Racepres's Avatar
Racepres
Originally Posted by hellonewman
The one I was talking to you about today has the reverse shift pattern and I've read many came that way. Some I read about said as late as 74 could've come that way.
Found this in an old post on this forum......
​​​​​​My 1974 FXE Superglide had one up, three down. Stock for that year. This pattern was favored by racers. In 1975 the the federal government mandated all shifters on bikes sold in the USA to be on the left side. Harley went to one down, three up in 1975. Yes, you can move the shiftdrum "up-side-down" to change the pattern. I personally liked the one up, three down.
Besides reversing the shifter drum cover, using a FL shifter cover will do the same
thing on an FX.
Yes and Yes...then No... Not that easy..
There really are two different Levers/Covers.. and there are Shift drums, marked FL and Drums Marked FX.. Got them right here...
The setup for an FX has the Drum with Lever pointing Up, while the FL, has the lever pointing Down..
a quick look will show Why some are Different than we expect.. and I Know that the MoCo screwed this up as well... certainly in 1974..maybe 1973...that I do Not have experience with..
Now...the 1971 and 1972 FX... yup All shifted Upside Down... Have to...as they All had the Stock Lever turned Backwards...How else Could it Work??? as they were FL tranny's and Shift Drums...
Old Aug 30, 2022 | 07:58 AM
  #72
hellonewman's Avatar
hellonewman
I'll leave it as stock, just need to remember what Im riding. Makes for a great antitheft device too.
Old Aug 30, 2022 | 10:21 AM
  #73
Racepres's Avatar
Racepres
Only thing to do, if you want it to shift One down 3 Up, is to Change the Shift Drum...so, Externally, it will Appear Stock!!
Old Aug 30, 2022 | 04:09 PM
  #74
Hey Man's Avatar
Hey Man
But... it is Important to Note... The Frame Rake Never changed... the effective rake (really the Trail Numbers) changed Only because the fork tubes growed longer... Look it up..
Thanks MoCo
I think the difference was in the trees. Otherwise how could the seat height be lower and the wheelbase be longer if the rake was the same but the tubes be longer? That would make the front end higher.
Old Aug 30, 2022 | 04:38 PM
  #75
magnum45pete's Avatar
magnum45pete
no difference in the trees (yokes),2'' longer fork tubes (stanchions) raise the frame slightly pushing the wheel forward & the seat was thinner,
they might have had shorter rear shocks as well but not 100% sure on them.
Old Aug 30, 2022 | 04:42 PM
  #76
Racepres's Avatar
Racepres
Nope... all Narrow Glide trees are Zero Rake..the FLH trees, since the intro of the DuoGlide..1958, all seem to be Minus 3 degrees.
FXWG... are Plus 3 degrees..
The fork tube length is so Variable...it would take alot of effort to Document it... The 4 speed frame... since 1958... is all the same Rake angle at the Neck!!!
The MoCo decided that they would Vary the fork tube length, to "claim" a different Rake... It works ... with a protractor.. But... it is Mis-represented...as the Frame Rake never changed.. the Trail Numbers Changed... Again... putting a protractor on the Neck will show the "effective" rake... which creates the trail numbers...
Old Aug 30, 2022 | 04:47 PM
  #77
Uncle Larry's Avatar
Uncle Larry
I've got 2" over tubes ( Forks by Frank ) on my and it often gets a "what's going on here" looks :>)
Old Aug 30, 2022 | 07:13 PM
  #78
Racepres's Avatar
Racepres
The funny part is...
2" over What??? FXE?, FXS? FXR?? FXWG?? Heck... FLT is about 4" over FLH!!!
Don't mean much anymore!!
Old Aug 30, 2022 | 09:50 PM
  #79
Uncle Larry
^^^ 1979 fxef ^^^
Old Aug 31, 2022 | 05:07 AM
  #80
magnum45pete
FXS tubes were 2'' over FXE length, so ya now have FXS length forks...
