Bad squaky sound when the engine runs.
Old May 15, 2021 | 11:48 AM
johnjzjz's Avatar
johnjzjz
One intake at full lift you adjust the other intake - then do the exhaust the same way
Old May 15, 2021 | 12:38 PM
Kimfromdk's Avatar
Kimfromdk
2nd Gear
Originally Posted by troy montoya
Hi Kim,
just to clarify , you should check one cylinder at a time Front or Rear but not both at the same time as you have pictured, sorry I should have ben more clear in my other post . . .
I did check one at a time. Just need to see the other was in top to have the other one to adjust.
Old May 15, 2021 | 12:41 PM
Kimfromdk's Avatar
Kimfromdk
2nd Gear
I did not really find anything to adjust. They all had no slack up and down and I could roll them around with my fingers. Should I still loosen them or is all good?
Old May 15, 2021 | 12:59 PM
johnjzjz's Avatar
johnjzjz
Good to go
Old May 15, 2021 | 06:15 PM
john lee's Avatar
john lee
good info john. easy to understand
Old May 16, 2021 | 09:06 AM
johnjzjz's Avatar
johnjzjz
2 brothers owned a Harley and bicycle shop and the mechanic brother worked for Indian in the 30s then Harley in the early 50s - i was just between 8 th grade and hi school showed me that when i had found a Indian put out for the garbage - and push it home - went to them for info in the early 1960s he helped me out
CaffeineBuzz
Apr 17, 2021 07:13 AM
ccardiff
Nov 21, 2014 06:45 PM
Curasam
Oil Archive (no new posts)
Apr 2, 2013 06:53 PM
Keithhu
Exhaust System Topics
Aug 24, 2012 06:07 AM
Nightster 13
May 22, 2008 08:14 AM
