Grease Suggestions
Old Jun 23, 2021 | 05:05 AM
Prop's Avatar
Prop
6th Gear
Default Grease Suggestions
I replaced the starter on my 1978 FLH 80 and I'm running a stock primary. What grease do I use on the starter shaft? The HD manual did not specify that I saw. Just engine oil?
Old Jun 23, 2021 | 07:58 AM
johnjzjz's Avatar
johnjzjz
the shop is - green grease from 2 guys garage - water proof very sticky and long lasting with hi slipperiness and sticky what else do you need on line best places shop a bit for better pricing
Old Jun 23, 2021 | 09:11 PM
carlgrover's Avatar
carlgrover
I got curious about what this green grease was so I googled it:
https://www.autozone.com/greases-and...rease/945652_0
When I had my Electra Glide apart I used Lucas Red and Tacky #2 on that shaft. I also used it on the clutch fingers, rollers, and the inner primary bearing. Just a little though. Probably better to get some of that green stuff.
carl
Old Jun 25, 2021 | 10:34 AM
Prop's Avatar
Prop
6th Gear
Thank you, I'll check out green grease.
Old Jun 25, 2021 | 04:31 PM
chopper_man's Avatar
chopper_man
Red and Tacky is my go to for all grease applications.
Old Jan 26, 2025 | 09:52 PM
AJ Brink's Avatar
AJ Brink
Ya guys I've been using green grease, great stuff. Just don't like the fact it's made in China. Seems all my parts or let's say several come from Taiwan. I put a thin coat on that spline the book says lubricate one. That stuff is no longer. That green grease is the best and I've been using it on a lube surfaces. Including my plunger on my Pogo and that brass insert.
Bagger G
Shovelhead
Jan 24, 2018 10:10 PM
curtisldean
Jan 15, 2016 12:42 PM
pjb
Shovelhead
11
May 5, 2015 04:31 PM
fatboyautos
Mar 28, 2011 06:14 AM
calex3517
EVO
May 2, 2009 10:23 PM
