Engine seal question
Old Jul 18, 2021 | 07:52 AM
Gappy's Avatar
Gappy
Default Engine seal question
I had to replace a leaking transmission seal so the inner primary had to come off. While I have it all apart I decided to look at the engine seal too.
Now my question is being that I have isolated my primary I have heard that the engine seal should be reversed, is this important? I have a new seal they are cheap enough and can do it now while it is apart.
Old Jul 18, 2021 | 08:11 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Leave it alone. They say it should be reversed, but in reality it makes no difference.
That is how I installed the seal in my `89 EVO, and it has been running like that for about 80,000 miles since with no issue.
Old Jul 18, 2021 | 01:41 PM
johnjzjz's Avatar
johnjzjz
The put it in reverse guys - are the same ones leaving the bar put it in D and aim it
Old Jul 18, 2021 | 05:06 PM
john lee's Avatar
john lee
dont forget to use a good sealant around the edge
Old Jul 19, 2021 | 12:02 AM
old mago's Avatar
old mago
My 82FLH with oem oil supply to the primary chain was in reverse from the factory. I replaced it (same as you when i replaced the transmission seal) the "normal " way round...no probs
BTW that alt winding looks like a two year old wound it. just sayin
Old Jul 24, 2021 | 02:24 PM
coax9952's Avatar
coax9952
Smile
That's all AMF could afford back then...…..
garystaven88
Shovelhead
Apr 6, 2020 06:47 PM
charlesrt88
Shovelhead
Sep 13, 2015 10:30 PM
HARLEY57PAN
General Topics/Tech Tips
Apr 24, 2013 08:38 PM
MrC
Jun 6, 2007 10:40 PM
moblue
Jun 11, 2006 04:20 AM
