Absolutely cannot get compensator nut off
Old Dec 27, 2021 | 07:48 AM
  #121
Newintown's Avatar
Newintown
Originally Posted by john lee
this problem must be 1 of a kind
Sure does feel that way. No updates. Welding is still on the task list.
Old Dec 27, 2021 | 07:01 PM
  #122
Redrodyankneck's Avatar
Redrodyankneck
Let's hope you have better luck next year! LOL
I'm thinking the weld method would be your best shot. I would cut away the brass around and under the old nut with a dremel, weld a new nut smaller than the comp nut so you can get a good bead around it, beg borrow or "rent" a Milwaukee 12v high torque impact ( 1400 lbs off.. oh yeah) apply heat and get it done.
Old Jan 23, 2022 | 09:44 PM
  #123
Ghost_Pony's Avatar
Ghost_Pony
I'd almost wager that the previous owner, (or the last wrench that worked on it), more than likely applied Loc-Tite 271 or 272, (Red) Loc-Tite to the threads, in somehow erroneously thinking that if torquing is good, adding red Loc-Tite will be even better. I haven't read all of the replies yet, so if you still haven't broken it loose, then acquire a 3/4" drive, 6-point, black oxide coated socket & have an 18"-24" piece of 1/4" thick strap steel welded to it, make sure that you've got the clutch drum properly locked, place the socket on the compensator nut securely, and step down on the bar.
I'm saying all of this because several months ago this is exactly what I wound up having to do when a guy brought me his 1975 FLH that had a compensator sprocket with several broken teeth on it. And after fighting with it for several days I called the guy to ask about any previous work done on the bike. He told me that he'd put a new primary chain, plus he'd upgraded the alternator to a 32 volt system on it two years previously, and since he didn't have a torque wrench he had slathered a healthy amount of red Loc-Tite on the threads & then "hammer-torqued" it good & tight. Fortunately I had a donator socket that I made my aforementioned alterations to, and with some assistance from a friend, we finally broke the nut loose. The nut itself had begun to fracture from all of the previous attempts, so it was a damned good thing that it finally broke free.
Old Jan 23, 2022 | 11:59 PM
  #124
john lee's Avatar
john lee
i finally thought that nut had come off
Old Jan 25, 2022 | 07:29 PM
  #125
carlgrover's Avatar
carlgrover
Yeah, there for a second I thought the blessed event had taken place.
carl
Old Jan 26, 2022 | 06:41 AM
  #126
kel03's Avatar
kel03
This still not off ??? It would drive me "nuts" knowing the challenge is in front of me.
Old Jan 26, 2022 | 07:05 AM
  #127
magnum45pete's Avatar
magnum45pete
I tell ya, by now I would have cut the damn thing off with an angle grinder & gotten a new sprocket shaft put in the crank,... if fact ya may as well do that couse you cannot by now even think it'll be fit for use if you ever got it off whole !
get the Makita out & cut it all off & the jobs done !!
Old Jan 26, 2022 | 07:10 AM
  #128
Redrodyankneck
I see what you did there!
Still there's no way to "compensate" for all that lost time.
Old Jan 26, 2022 | 10:32 AM
  #129
NZAL's Avatar
NZAL
Don't you guys start with all that torque now.
Old Jan 26, 2022 | 01:22 PM
  #130
johnjzjz's Avatar
johnjzjz
