Smoking
Old Aug 21, 2021 | 03:19 PM
johnjzjz's Avatar
johnjzjz
We use Yama bond 4 on the rocker box gaskets - coat them heavy both sides thick and install
Old Aug 21, 2021 | 08:04 PM
hawg1982's Avatar
hawg1982
Yama bond yea I seen that on a post....have to find a Yamaha store not one around here. Honda store is the only one close that's 30 miles from here.
Old Aug 21, 2021 | 08:41 PM
johnjzjz's Avatar
johnjzjz
Amazon or e bay
Old Aug 21, 2021 | 08:58 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Interesting how things go sometimes. My 76 FLH started putting out a little white smoke from the rear cylinder in about 99 when stopped. A few years later a little bit from the front when stopped. Motor is still running good about 50,000 miles later. Just came back from a ride today and folks told me how much they liked the sound, they never talked about the smoke. I have two other bikes that I ride in rotation but I still feel most at home on this old smoker. It's amazing how far these motors will go if built right.
Old Aug 22, 2021 | 07:48 AM
johnjzjz's Avatar
johnjzjz
A huge difference between riding it like a human - and a loony tick moron
Old Aug 23, 2021 | 09:40 AM
Hoyt 1911A1
That may very well be the difference John. I remember guys constantly tearing their engines down chasing every little strange sound and puff of smoke. Seemed like they were always having problems, even on the early Evos. I remember one guy telling me years ago that my motor was about to blow. Funny thing is he snapped his belt a few days later. Riding style may just be the difference.
I can't afford to chase every little weird sound and leak. If it ain't dangerous or running bad I'm gonna leave it the heck alone.
Old Aug 23, 2021 | 09:27 PM
80Glide's Avatar
80Glide
Honda bond (I’m not kidding) and Yama bond same thing. Used for sealing crankcase halves without a gasket on those bikes. Make sure to get #4
Old Aug 28, 2021 | 02:07 PM
hawg1982's Avatar
hawg1982
Okay started taken Rocker and head off....once I got the Carb and Exhaust off I seen oil in the ports. So theres oil inside the ports now have to see what's causing it. Will finish getting the Head and Rocker off Sunday or Monday.....
Old Aug 28, 2021 | 02:59 PM
johnjzjz's Avatar
johnjzjz
Tin seals and or the incorrect travel for the valve springs - camshaft install - many read fits all stock engines YEA that is true but the spring spacing has to be adjusted and they for go telling you that - but in a shop that not selling f housework underware we check and adjust the springs travel with the seal installed and you want at least .060 at full lift - bottom of the top retainer to the top of the seal including the camshaft lift say .450 + .060 = .510
Old Sep 3, 2021 | 01:30 AM
hawg1982's Avatar
hawg1982
Okay got Heads and Rockers off
FT Heads has oil thats burnt into head some and can rub oil and it's on finger
No marks on RR Heads rub exhust port be smutt
Going to tried and putt on Pictures..
PICTURES ARE BELOW.....took few times and I got them.....Look them over and see what you can. I know be better in person but it's better than a drawing
5th one down is from Ft Hea
13 Picture of Head if Ft
