Sorry should of put year of bike.
1982 Superglide HD
Motor been rebuilt in 2000. Has dual plugs, dyna s ignition. SS Wheel 4 1/4, SS Pistons 30 over, SS E Carb.
BIKE started Smoking out of front exhaust pipe. When I come to a stop it Smokes (not camels) looks white, maybe lite gray
Ideals to start checking for problem....
82 is an 80 inch - the .030 is the end for boring - yes they make .040 but it wont last a season riding before over heating
you had 20 years on that combo - time to pull the top end and check front rod twist - this will tell you condition of the lower unit - ask once its off what to do
then the cylinders condition picture that up the guys will help with the visual - oh the 2 heads and replace the lifter rollers or good USA lifters - check the cam and breather bore for damage - it could become costly
