Riser bushings
Old Aug 22, 2021 | 08:42 PM
SparkyD's Avatar
SparkyD
Default Riser bushings
Going to order some new riser bushings. Let's get some opinions and experiences with what ever brand you think is the best . . . and GO!
Old Aug 22, 2021 | 10:25 PM
TwiZted Biker's Avatar
TwiZted Biker
Any of the poly bushing I've had from Taiwan Teds to the pricier brands have been fine on the shovels with tall bars. Rubber go dealer on them, cheaper imports are trash. I've been using the Midwest or Jireh's for years with no issues.
Old Aug 23, 2021 | 09:46 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Gonna follow this thread. The front end on my Shovel has a slight rake and 8" over tubes. Many many years ago I THINK I put poly bushings in there to replace the solid steel ones that were on the bike when I got it. Lately I've noticed that the left handlebar is higher than the right when going straight from the years of stress lifting the bike off the side stand.
Don't want to put the solids back in but hopefully a good set of polys will straighten the bar out again. My old mechanic would always give me grief about that front end making it hard to set the bike up ad ride it through a parking lot. I always told him it was a welcome trade off for the extra stability at speed.
Old Aug 23, 2021 | 03:35 PM
carlgrover's Avatar
carlgrover
I put imported cheapy poly bushings on mine. No problem.
carl
Old Aug 23, 2021 | 07:52 PM
SparkyD's Avatar
SparkyD
Not sure how long my existing ones have been on the bike. I'm thinking they are original 1979 OEM, right now they smush like a wet sponge. I'm learning to stay away from the cheap stuff when it comes to shovelhead parts (or any parts for that matter). My riser top clamp cracked in 2 places the other day. After investigation I believe it's a result of my bushings turning to mush. Too much stress for that top piece riser clamp to take.
Any experience with the difference between 3 piece or 4 piece risers? Since I'm replacing the bushings I started looking at the difference between 3 and 4 piece risers.
Old Aug 23, 2021 | 08:08 PM
TwiZted Biker
3 pc will hold the bars square with the upper tree better than the 4pc will. I've alway had trouble with the individuals allowing the bars to to twist unless I used solid bushings. The old pot metal diecast and cast alum sets will warp or pull threads over time particularly with taller bars. Helicoiled a lot of the diecast for peeps. Billet stuff while pricey is the **** for a solid feeling set of risers
PS with the poly bushings only thing varies on them I've seem is the price so don't think your getting a better product if they cost more.
wyotana
Jun 19, 2019 05:52 PM
megatoph
May 10, 2017 01:41 PM
fnunez
Aug 30, 2016 03:19 PM
heckfrozeover
Jun 25, 2013 07:50 AM
DR. V-TWIN
May 30, 2010 09:54 AM
