Exhaust Flange Bolt Hole Repair
Old Sep 27, 2022 | 07:17 PM
garystaven88's Avatar
garystaven88
Default Exhaust Flange Bolt Hole Repair
Ah yes the dreaded boogered up Shovelhead exhaust flange bolt hole.
1984 FXSB with oem heads. Running a Thunderheader that I have shimmed as best as I can at the rear mount to keep zero stress at the heads.
Both heads were helicoiled by a PO and it lasted quite a while. The front one is still holding up just fine.
I recently have had issues with the rear pipe bolt backing out and falling out. The helicoil there was boogered up and loose.
Earlier this summer I re-installed another helicoil (5/16-18). It now is starting to back out. It loosens up when the engine is hot.
I am taking a peak at Time Serts. I see they offer what's called a "Big Sert" to use in holes which previously had a failed Helicoil.
Has anyone had experience with these?
Being a Thunderheader, I can't really use two studs but I think I could manage to use a stud on the rear pipe and continue to use the bolt on the front pipe. Thoughts on that? I know it is preferred to use studs instead of bolts here.
Old Sep 27, 2022 | 10:59 PM
john lee's Avatar
john lee
ive read where some use time serts with no problem i used a heli coil on mine 35 yrs ago and still there,but used loctite on it too
Old Sep 27, 2022 | 11:50 PM
Squidbilly*'s Avatar
Squidbilly*
Try Safety wire before ya go to drilling & taping,
Old Sep 28, 2022 | 02:21 AM
john lee's Avatar
john lee
there was something you could buy that attached to the bolt and pipe to supposedly fix that problem .some might remember it
Old Sep 28, 2022 | 06:38 AM
garystaven88
Problem is the helicoil itself is pulled out of the head. I agree with safety wire for the bolt but I need a solution for thread repair.
Old Sep 28, 2022 | 07:48 AM
Racepres's Avatar
Racepres
"Big sert" or.. go to Fastenall... get thick wall threaded insert...If Needed.. the thinwall is much thicker than a Helicoil..
Then use a Stud, with nut.. Not a Bolt
Old Sep 28, 2022 | 10:50 PM
Squidbilly*
Got ya,
My bad,
Old Sep 29, 2022 | 09:27 AM
Racepres's Avatar
Racepres
Reason to go with Fastenall is the threads are Standard... Not some Proprietary stuff...
ie 3/8 OD with 5/16 ID... could even go Fine threaded ..which would be Better yet for Stud... not necessarily on the OD of Insert into aluminum!!
Old Sep 29, 2022 | 09:44 AM
Uncle Larry's Avatar
Uncle Larry
Maybe
https://www.stage8.com/
Old Sep 29, 2022 | 09:46 AM
Uncle Larry
I've not had problems with my Shovel pipes ... I had a buddy who welded up a boss for an additional bolt and reworked the flange on his ... It was a pretty slick repair
