81 FXE Restore
I'm in the auto building industry, several decades now. Fasteners are very serious business and designed for specific application and specifications. Elongation and deliberate stretch are very real going back to early aircraft engine designs. One shot fasteners are the thing on most everything for decades now. Isn't myth or internet repeated fairy tales. Why most serious engine hardware is replaced once used today, the base properties changed when torqued and ran through heat cycles. It's deliberate metallurgy and physics not redneck hearsay. Idea was build in some give to help not chew the old garlock gaskets up through the heat cycles, radial aircraft engines used similar tech year back with about as much success not leaking.
Owners and backyard mechanics usually screwed that pooch over tightening slathering on gasket sealers allowing the gskets to squish out on the corners under the stud holes.
Nobody said **** about shovel cylinders by the way, we're chatting about cast alum heads and rocker boxes not cast iron, huge expansion factor difference. Shovel head bolts and base studs are as grunt proof you get, why you see rounded base nuts and head bolts or pulled thread bosses in the heads or the cases, they don't stretch and I've never seen one break.
And just out of curiosity how did you arrive at the .100" growth measurement?
Watched a couple different build engines bolted to a static test stand and run with dial indicators on each head through several heat cycles, low was .065" high was a hair over .100" growth at running temps. Chopper shop/builder in KC was geeky about his stuff but very interesting to hang out with when the game was on.
if ya look at old Harleys like Knucks, 45's pans etc, everything used with a thread, they used the best thread needed for its use, so fine, coarse,special pitch, cycle threads etc even bsf,whitworth were all used (well, don't think Harley used Whitworth but ya get wot i mean) if it were the 'right' item for the job.they used it..
all fixings have an optimum use, torque grade & material, & in the day, the right/best thread was used & to hell with the cost.
now its a compramise, penny pinching use of metric is easy & works, saves cash, but not the best from an engineers view,
older bikes were over engineered, and now we know to use fewer threads & forms as modern specs are not as high as they were,
and as so some bolts, studs nuts etc are at their limits when in use, so need replacing as 'Service Items' more often than on older motors where the correct bolts were used in the first place plus less stress was put through them,..
I have a cast iron lapping plate I use on stock ones to get them flat again, never had a set off that weren't tweaked.
