Height difference, normal?
Old Jan 20, 2023 | 07:20 AM
JOHNNYROTTEN 1's Avatar
JOHNNYROTTEN 1
Originally Posted by Scrmnvtwins
Someone above had suggested your primary was for a belt application. This is a Sturgis FXB which is the primary belt drive as well as final belt drive. (Twin Belt) Ive owned 6 Harleys and still have 3. I have never seen the significant step you show in your initial picture. I have seen inner primary chrome covers that are placed on top of the inner primary outer surface. Those dont always fit well and they are like a tin shield over the outside. Is it possible you have a chrome beauty cover over your inner primary?
Good thinking, but I've just been in the garage, and as far as I can see, there is no cover.
I'll get a better idea when I eventually take the inner chain case off. I was going to do it at the
weekend as the weather not too good, but apparently the weather will be nice, so I'll go for ride before
fixing the leak on the gearbox.
Old Jan 20, 2023 | 08:56 AM
Joe12RK's Avatar
Joe12RK
Just a thought - here is a picture of Troy's low miles 1985 Evo FXSB, and it has the same raised lip:
Old Jan 20, 2023 | 09:21 AM
JOHNNYROTTEN 1
Ah yes, I think mine has one because it has a belt final drive conversion.
Still can't do much about it, unless I convert to chain and find another chain case. Which would be too expensive ATM.
Thanks for the picture. It looks better in Aluminium.
Old Jan 20, 2023 | 03:05 PM
john lee's Avatar
john lee
a good alloy polish job will look like chrome. i would not have a chrome one
Old Jan 20, 2023 | 03:24 PM
TwiZted Biker's Avatar
TwiZted Biker
Don't worry about it, I've seen the fit between cases and primary covers all the over the spectrum. Everything fits and works correctly with no leaks run with it.
Old Jan 20, 2023 | 03:48 PM
JOHNNYROTTEN 1
Yes, I'm resigned to putting up with it now, but it still comes to the forefront that it looks bloody awful.
Maybe I'm just being too fussy.😁😁😁
Old Jan 20, 2023 | 04:10 PM
TwiZted Biker
Could be worse, some of the chromed aftermarket stuff back when was a crime it was so bad. Ever run across anything with the name Lifeline it's pure junk, avoid it.
Old Jan 24, 2023 | 04:10 AM
Bmp72's Avatar
Bmp72
I recognise the X30-00085 number... its the stock Harley inner primary for the Sturgis and FXDG model (bikes that came stock with a belt primary).
My FXDG also has the large offset between primary and motor, its so bad the clear plug wont screw into the hole in the crankcase to set the timing. But the bike rides fine so I am not worried.
Old Jan 24, 2023 | 04:33 AM
JOHNNYROTTEN 1
Yes, it's annoying, but just have to accept it the way it is.
I'm trying not to think about it, which is difficult. 🙂🙂🙂.
But as I'm riding, all the cares in the world disappear.😁😁😁😁
Bigdozer69
Shovelhead
Dec 9, 2022 06:59 AM
gwhite
Welcome Area Only
24
Dec 1, 2021 02:08 AM
Wolfy.75
Welcome Area Only
24
May 27, 2021 08:00 PM
Billd34668
Welcome Area Only
Apr 26, 2021 04:43 PM
moparleo
Welcome Area Only
25
Feb 1, 2021 09:32 AM
