Chain Drive Recommendations
Old Apr 5, 2023 | 03:28 PM
MarkSG's Avatar
MarkSG
Originally Posted by Rains2much
inside of your primary will get trashed… ALWAYS stick with a 23 on the tranny. If you have a stroker maybe think about a 46 or 47T rear gear. If it’s a 74 or 80 inch even with cam and maybe a little extra compression try to go 49. If it’s a bar hopper go 51T
I don't understand this comment. What gets trashed and why?
I am familiar with the larger front sprocket allowing the chain to hit the back side of the primary and trans but have not heard of any issues with the inside.
Old Apr 12, 2023 | 07:53 PM
Spanners39's Avatar
Spanners39
He means the part where the starter bolts on, with a 24T and an O ring chain it will eat the primary away at that point.
i run a 24T and a non-O ring chain and all is well...just.
Old Apr 13, 2023 | 06:12 AM
MarkSG's Avatar
MarkSG
Default Primary
I figured as much but he said inside primary. That and I don’t understand why an oring chain would cause a clearance issue.
Old Apr 13, 2023 | 05:44 PM
Spanners39's Avatar
Spanners39
Because that are is part of the inner primary cover I guess...O Ring chains are wider, as well as taller as the witness marks on my inner primary will attest.
Sauraus
Jan 10, 2025 04:23 AM
Rollbar
May 7, 2015 04:48 PM
dukeinhaler
Ironhead
Aug 27, 2014 08:46 PM
gabulldog
Aug 23, 2010 04:51 PM
Crazy03
Oct 3, 2007 07:16 AM
