Chain Drive Recommendations
Old Mar 27, 2023 | 01:41 PM
HellaGNARLY's Avatar
HellaGNARLY
Default Chain Drive Recommendations
Any recommendations for a new drive chain? Will all 530's work or will I need a specific style? 84 FXE hardtail - I believe OEM is 530/102.
Thanks.
Old Mar 27, 2023 | 04:32 PM
Spanners39's Avatar
Spanners39
They all fit but don't use an O Ring chain if you have a 24-tooth front sprocket and electric starter things get ugly. RK or DID for the win.
Old Mar 27, 2023 | 04:38 PM
Rains2much's Avatar
Rains2much
inside of your primary will get trashed… ALWAYS stick with a 23 on the tranny. If you have a stroker maybe think about a 46 or 47T rear gear. If it’s a 74 or 80 inch even with cam and maybe a little extra compression try to go 49. If it’s a bar hopper go 51T
Old Mar 27, 2023 | 04:50 PM
HellaGNARLY
Stock 80"
Old Mar 27, 2023 | 07:28 PM
Y2K's Avatar
Y2K
I rab an RK on my '84 FXR,it was good for the price,another good one is Tsubaki .
Old Mar 28, 2023 | 01:29 PM
Redrodyankneck's Avatar
Redrodyankneck
I used DID several times and quality is good. Found a few good deals on Flea bay couple years ago when I has shopping.
Old Mar 29, 2023 | 09:44 AM
rockher_man's Avatar
rockher_man
Default Chain & 24 tooth front..
My 1979 Electra Glide FLH King of the Highway full dresser Shovelhead has been running a 24 tooth front & o-ring chain with 51-tooth rear since 2001 "upgrades".
NO worries! 😎
Old Mar 29, 2023 | 03:22 PM
john lee's Avatar
john lee
NO worries! 😎
the 51 lowers revs ? what would a 22-49 combo do on a fx
Old Mar 31, 2023 | 09:33 AM
Rains2much's Avatar
Rains2much
as said.. I only like a 23 on the tranny. Too many issues using 22 or 24. With a stock motor a 49 is about all I’d go down in revs. You need more power to go 48-45. Raising rd stir more pep a 51 is about as high as I’d recommend. You do t wannabe 4000rpm at 55 mph
Old Apr 2, 2023 | 04:30 PM
john lee's Avatar
john lee
mine had a 23-47 at first and when my hd mech had the inner primary off said to change to a 22-49 but i cant remember why. i think it was about same speed less revs
