Primary Oiler
Old Sep 24, 2023 | 06:34 AM
Baird's Avatar
Baird
The adjustment screw, is for the rear chain only. The manual quote pictured is wrong. I might guess its not an official HD publication.
The oil flow is controlled by the timing of the breather valve and partial vacuum in the crankcase.
Old Sep 24, 2023 | 06:47 AM
jimessbee's Avatar
jimessbee
That quote is for the section for the primary. And as you said… the adjustment is for the rear chain. How is the manual quote wrong?
I’ve read the quote Paul pictured as well. It’s a different page is all. But it doesn’t mention adjustment.
Old Sep 24, 2023 | 08:02 AM
Baird's Avatar
Baird
I was referring to the "orifice screw" part. If I'm not mistaken, the only orifice screw I see is the rear chain volume adjusting screw on the back of the oil pump.
Refer to page 3-9 of that manual and see item 11, the routing of the oil is right from the breather valve with no screw or other "throttling" means.
Old Sep 24, 2023 | 09:13 AM
rockher_man's Avatar
rockher_man
Default Oil!
Just isolate the primary. Cap that feed.
Run an o-ring chain and close-off rear oiling.
Use chain WAX not chain oil as needed.
No worries.
Old Sep 24, 2023 | 12:42 PM
jimessbee's Avatar
jimessbee
No worries.
That is my previous experience. But I kind of like the idea of that oil dripping on the primary.
Old Sep 24, 2023 | 02:12 PM
WXSW's Avatar
WXSW
For the suggestion to isolate the primary, what exactly are the advantages? Is it to create a streamlined system with more user control over things, or are there other benefits? The previous owner of my 1980 FLH disabled the rear chain oiler, which is good because I use a wax lube and I don’t want motor oil slinging off the chain. My primary chain oiler and scavenger works fine and I am guessing it’s been a reliable thing on the bike for many years. The chain looks good, the primary area is clean and has very little oil buildup. It seems like a good system that does what it’s supposed to do.
Old Sep 24, 2023 | 02:13 PM
s-glide76's Avatar
s-glide76
Thanks for posting that video, pretty cool. My 82 fxr is still set up that way and that's the way I'm going to keep it.
Closing off the primary and adding a 8 ounces of fluid didn't work for me on another shovel with a dry clutch.
Old Sep 24, 2023 | 02:36 PM
Y2K's Avatar
Y2K
Originally Posted by jimessbee
I am having a hard time imagining negative ramifications of it being too much. But would love insight.
It's not good for your clutch plates unless you've upgraded to something like Barnett wet or dry discs.
Speaking of, frankly I'd plug off the oiler and return lines, seal the primary case and run the wet or dry discs with just enough oil to catch the chain,I did that on my old FXR and ran a little ATF in the case to keep the chain lubed.
This also keeps clutch wear debris from going back into the motor oil ,even though it goes into the oil filter it's better to not have that at all.
Another thing I did was get the crankcase breather hose out of the airbox and plug the hole in the airbox so there's no oil going into your airleaner and carb.
Just run the vent line hose down under the motor and zip tie it to the frame,maybe put a little filter on the end of the hose.
Old Sep 24, 2023 | 02:49 PM
Y2K's Avatar
Y2K
Question
Why is that? Stock clutch plates maybe?
It worked great on my FXRS with Barnett wet or dry friction discs,while I was at it I upgraded the 3 finger plate to a 5 finger plate.
WXSW's Avatar
WXSW
Originally Posted by Y2K
…..keeps clutch wear debris from going back into the motor oil ,even though it goes into the oil filter it's better to not have that at all….
That is a benefit. One of the advantages of having a dry clutch and the clutch in a separate case from the crankcase. Keep that debris away from the engine, but as you said it does go through the filter.
