Primary Oiler
Old Sep 25, 2023 | 09:53 AM
  #31
s-glide76's Avatar
s-glide76
Originally Posted by Y2K
Why is that? Stock clutch plates maybe?
It worked great on my FXRS with Barnett wet or dry friction discs,while I was at it I upgraded the 3 finger plate to a 5 finger plate.
It would splash onto the clutch plates, glazing them and causing it to slip. It seemed like every 3 or 4 thousand miles I was removing the clutch plates and scuffing them up again.
Old Sep 25, 2023 | 10:02 AM
  #32
s-glide76's Avatar
s-glide76
Originally Posted by pgreer
It's been a while since I watched the oil flow from the primary chain oiler, but the amount of oil is about what I remember. The chain does a good job of slinging the oil around to the parts that require it. But I did incorrectly remember that the screw on the oil pump controls oil to the rear chain.
That said, many people eliminate the oiler and return because you are cycling oil from the primary that likely has some metal shavings and clutch material into the engine oil. And, notice that they do not do it that way on newer bikes. I changed mine over a long time ago and simply change the primary oil once a year.
Paul
The clutch "dust" and chain /sprocket debris is why I would switch them over in the 80's. And less oil lines to leak is a plus.
But now I figure the magnet on the drain plug should trap the metals and the filter will capture the non metallic pieces.
All the other manufacturers with a single oil for motor, transmission and clutch seem to last forever.
Old Sep 25, 2023 | 09:00 PM
  #33
Y2K's Avatar
Y2K
Stock clutch plates? I never had an issue with Barnett wet or dry plates in my FXRS
Old Sep 26, 2023 | 07:39 AM
  #34
s-glide76's Avatar
s-glide76
Yes they probably were either stock, custom chrome or drag specialties dry plates.
Back then I probably put on whatever was cheapest.
Old Sep 26, 2023 | 11:10 AM
  #35
pgreer's Avatar
pgreer
Alto clutch disk in my Shovels, they are good for dry or wet. They weren't the smoothest but never slipped.
Paul
Rovens77
Panhead
11
Aug 23, 2022 07:11 PM
Bill wallace
Shovelhead
Jul 24, 2017 07:24 PM
lunyty1
Shovelhead
Oct 29, 2015 06:36 AM
steveh326
Jan 27, 2008 05:48 PM
Coaler
Classic
Jul 9, 2005 10:31 AM
