Import Bendix carb kits
Old Feb 17, 2024 | 07:32 AM
ftwflh's Avatar
ftwflh
Default Import Bendix carb kits
Has anyone else had trouble with one of these kits? I cant seem to get the float needle to seat properly. Found a old original needle and going to swap it out and see if it holds. The clip on the import is way different than the original. I am thinking the design of the clip that goes on the needle is too wide and not letting the needle seat properly.
Also the black accelerator pump was a joke.Had use a decent old take out one. I cant hardly bring myself to paying $80 for a Bendix brand kit.
Any input appreciated
Old Feb 17, 2024 | 09:20 AM
Racepres's Avatar
Racepres
Wouldn't Dream of one!!! Problems Years ago already... Zenith/Bendix, Facet Fuel Systems, still makes the Real Thing!!!!!
You Get what you pay for!!!
Old Feb 17, 2024 | 12:06 PM
magnum45pete's Avatar
magnum45pete
buy the genuine and pay up, one of the things with Harleys,...
buy cheap and spend time working on them, spend on quality parts and spend time riding
Old Feb 18, 2024 | 06:37 AM
1981 suprglide's Avatar
1981 suprglide
far as carbs S&S got it locked down. it's not cheap doe.
Old Feb 18, 2024 | 07:57 AM
ftwflh's Avatar
ftwflh
I want to keep the internal throttle wire. Dont think I can do that with S&S Super E. I would have to change bars and find throttle cables and housing.
Old Feb 18, 2024 | 08:03 AM
ftwflh's Avatar
ftwflh
Hey Marty I am having trouble gettting the float to shut off. The import needle is longer and I had to readjust the float and it still flows right out of the carb. Put another stock one in and the same thing.
I have the float set at 3/16th and with one of my 3 needles I can hold down on the float and it seals off good. Put it on bike and gas flows right through. You think I may have the float spring wrong?
If so can you send me pic of which way it is supposed to go.
Old Feb 18, 2024 | 07:53 PM
80Glide's Avatar
80Glide
I’m not familiar with this particular carb but I have run across instances where the float doesn’t float anymore. Particularly with a brass float. It’ll get a pinhole and fill part way with gas. If it is brass and doesn’t float you can find the hole by putting the float into a pan of water, heat it and watch for a bubble
I’m not sure if your float is brass though.
Old Feb 19, 2024 | 07:26 AM
Architect's Avatar
Architect
I have a stock throttle spiral setup with a S&S and it is still internal. Takes a minute to get a throttle cable the correct length, cut it and make it work, but it can be done.
Old Feb 19, 2024 | 10:21 AM
ftwflh's Avatar
ftwflh
Can you send me pics of how you set this up?
Old Feb 19, 2024 | 10:24 AM
ftwflh's Avatar
ftwflh
I have tried 2 different floats. Surely both wouldnt be bad but I will check them
