Damaged O-ring lip on engine case (Fix) ?
Old Feb 18, 2024 | 01:19 AM
troy montoya's Avatar
troy montoya
Question Damaged O-ring lip on engine case (Fix) ?
Hello every one ! hope your enjoying the weekend !
i have a question for you all, i have a cracked / broken O-ring lip on my engine case where it seals up the inner Primary, i see this kit is used to repair or replace the damaged O-ring lip , my question is do i need to completely remove the rest of the undamaged lip ? any suggestions are welcomed ! thanks
any one use this repair kit ? any advice is welcomed !
Old Feb 18, 2024 | 06:28 AM
RANGER73's Avatar
RANGER73
A picture of the damaged lip would be more likely to get you an answer
Old Feb 18, 2024 | 06:37 AM
johnjzjz's Avatar
johnjzjz
No the kit is to aid in the fix - also actually striping the engine to the cases and welding and then machining is the real fix BUT not necessary
do not remove and more of the cracked or broken off ring
Old Feb 18, 2024 | 09:45 AM
sbrmike's Avatar
sbrmike
I think there are two different manufacturers or marketers of the exact same kit. The one I used said to the remove the lip, I saw where others said you didn't have to remove the lip. I went against the instructions in my kit and did not remove the lip. It has held up for years. You do not have to remove the lip, regardless of what the instructions say.
Old Feb 19, 2024 | 07:11 PM
pgreer's Avatar
pgreer
Follow what John said. If you (or anyone) wants to repair it correctly later, removing more broken material will likely make it harder to repair.
Paul
Old Feb 19, 2024 | 07:25 PM
Schex's Avatar
Schex
If you see any areas that's cracked enough that might eventually break off, I'd probably remove that, otherwise leave it.
rykk
Shovelhead
Jan 21, 2023 11:17 PM
Gappy
Shovelhead
Jul 24, 2021 02:24 PM
garystaven88
Shovelhead
Apr 6, 2020 06:47 PM
knightenforcer
Jul 6, 2013 01:16 PM
jhnmflr
Exhaust System Topics
Dec 2, 2006 07:13 PM
