Kicker Conversion. 1980 FLHS. Grrrrr!
Old Mar 5, 2024 | 11:38 PM
Berock's Avatar
Berock
Default Kicker Conversion. 1980 FLHS. Grrrrr!
Put a kicker in they said. It'll be easy they said... It bolts right in they said.
Ok, I ran into a problem with this kicker add to my 1980 FLHS.
Everything I have seen shows a separate kicker stop bracket held on with two screws... When I open it up, I see a kicker stop integrated into the bearing retainer... Ok, no big deal... But the kicker doesn't clock to 90°... Under the bearing retainer, there are no holes to attach the kicker stop bracket...
I guess I'll shorten the stop on the original bearing retainer. I see the earlier bearing retainers don't have an integral kicker stop.
Parts are:
S&S cover, Baker gears and a Jim's normal length kicker shaft.
It's interesting that the countershaft is held in place by the main bearing retainer... It fits in a slot in the shaft. Also, the oil hole into the main gear box is higher than in the earlier transmissions.
Thoughts?
ADDENDUM: OK, I figured something out... The instructions Baker has for clocking the gear is wrong for this setup. Once I figured that out, it all works -- but the kicker lever is still out a bit... I will have to shorten the stop a little bit. Going by the instructions, I guess the pin wasn't on the stop or something. Anyway. it's not just bolt in.
Old Mar 6, 2024 | 11:36 AM
Racepres's Avatar
Racepres
Now
Just to throw some gas on the fire...You pick an exhaust?? Or just gonna cop out to cheap azzz Drag Pipes??
Old Mar 6, 2024 | 03:28 PM
Berock's Avatar
Berock
Originally Posted by Racepres
Now
This is me. To be VHT flat black.
Old Mar 6, 2024 | 03:51 PM
johnjzjz's Avatar
johnjzjz
You have a may tag shift top and not a ratchet top reason it does not have the boss for the stop foot
we use another may tag bracket and bolt to till we get what we want in the kicker stand up then weld it In place
Old Mar 6, 2024 | 04:02 PM
Berock's Avatar
Berock
Oh yeah... A bolt is a great idea... Thanks. Weld on piece with a threaded hole first...
It's strange that I haven't run into this rotary top issue online... It's obvious now that you point it out.
The crappy kicker kits (that include the ratchet-top stops only) are for "1937 to 1986"... You'd figure after so many years they would update it. I originally bought one of those shi*ty kits and it took 15 seconds to discover how terrible it was.
Old Mar 7, 2024 | 05:45 PM
johnjzjz's Avatar
johnjzjz
Once you get it its a thing in the past - always - always something is awry today
you don’t want to chase parts for 75 year old machines
Old Mar 8, 2024 | 01:15 PM
Harleyryder12345's Avatar
Harleyryder12345
1st Gear
Default Do you have any bikes for sale in Jersey area?
Do you have any bikes for sale in New Jersey
T_levan84
Flathead
Mar 7, 2024 08:56 AM
Bumpandrun
Milwaukee Eight (M8)
39
Apr 5, 2020 10:57 PM
louu
Sep 23, 2019 08:40 AM
maverick31210
Apr 4, 2018 12:21 PM
JRK5892
Aug 19, 2014 06:52 AM
