torque plates
Old Apr 4, 2024 | 02:09 PM
clutch duster's Avatar
clutch duster
3rd Gear
can someone answer my question SMH
Old Apr 4, 2024 | 02:10 PM
clutch duster
3rd Gear
Originally Posted by djl
i deleted your post in the engine/mechanical section; double posting is not allowed.
I noticed this is your first post. If you plan to hang around the forum, suggest that you go to the welcome section, introduce yourself and read the forum guidelines. I will try to move tommy cs reply from the duplicate post to this thread.
your so awesome !!!
Old Apr 5, 2024 | 07:23 AM
magnum45pete's Avatar
magnum45pete
we have answered,... shovels DO NOT NEED torque plates to bore cylinders, they are ONLY NEEDED ON ALLY CYLINDERS FROM EVO'S UP !!
did you not see the numerous posts telling you this ?....
Old Apr 5, 2024 | 01:52 PM
clutch duster
3rd Gear
all I wanted was hole location,,not a education on boring iron cylinders ,,again can anyone answer my question ???I guess not
Old Apr 5, 2024 | 03:33 PM
FL54's Avatar
FL54
Notice that you are new to the site and no offense intended, but attitude won’t get you far in this section.
Old Apr 5, 2024 | 10:04 PM
Rains2much's Avatar
Rains2much
Again. If you want to make some order some 3 5/8 copper gaskets. That will be a good template. If you don’t know how to enter those measurements in the digital domain than maybe learn how to do that.
Old Apr 6, 2024 | 06:04 PM
clutch duster
3rd Gear
problem being the holes are not equal to each other ,,,, I came up with 4.750 bore center for hole location,,,,, degrees of off set is 0 deg 66 deg 140 deg 215.5 deg 298 deg and back to 0 degrees ,,,,,,,,,,,now some one tell me I'm off on one because it works but the bolts are a tight fit and I believe there a loose fit with the head installed on the cylinder ,,,now if you follow that I would still like to know degrees or x and y coordinates ??? precisely thank you.
Old Apr 6, 2024 | 06:13 PM
Ohio HD's Avatar
Ohio HD
Since it seems that you must have a mill with a DRO, clamp the cylinder down and use a pin gauge that just fits in the head bolt bore. Touch off at each location and note the readout.
Old Apr 7, 2024 | 08:33 PM
Max Headflow's Avatar
Max Headflow
Forgot to zero the DRO on the bore center first. Want more accuracy? Indicate the holes after the pin..
I like the idea of not using the top cylinder ring.. I have a set of jim's evo/shovel TQ plates and need to fit pan cylinders.. The bottom plate fits the pan cylinder base.. Easy way to hold the cylinder..
drm1978
EVO
Jun 5, 2020 10:47 AM
are6rider
Engine Mechanical Topics
Jun 23, 2019 08:12 AM
LeadDoggy
EVO
15
Apr 30, 2019 02:58 PM
m1crazy
Jan 27, 2013 04:18 PM
dawg
Nov 1, 2006 12:00 PM
