I hate the starter buttons on Shovels , intermittently work then dont work . I installed a waterproof button the sides of my dashes . Both have never had one issue since doing it . Seems as a stupid thing to say but check battery and ground cable connections , tight and clean .
My battery connections are good. I replaced the cables with new ones from all *****. I think at some time they were replaced with automotive cables. they didn't fit so well and looked beat up.
Need to use a VOM , to determine if the button is sending the signal to pick up the starter relay . As stated if you hear it click normally its good , but not 100% of the time . If you hear the click check voltage at the started cable and determine voltage at that point . Lots of places to have an unknown loose connection . Volt Ohm Meter is your friend in this case .
I didn't know you were on the Island. Sunday is a big truck show at The Maples in Manorville, I will be riding my '70 FLH to the event. Stop by and say hi, mine is the one with bright blue paint and too much chrome.
What time is that show? I will be taking the OP ferry Sunday morning and could stop by.
