Stripped stud
Old Jun 26, 2024 | 07:15 AM
jeeperjo's Avatar
jeeperjo
Default Stripped stud
I finally stripped a head stud. I'm assuming this can be fixed with a 3/8-16 helicoil.
Old Jun 26, 2024 | 07:22 AM
Uncle Larry's Avatar
Uncle Larry
Heli-Coil or a Timesert ... Time sert is a bit easier t use but a little more pricey
https://www.timesert.com/
Old Jun 26, 2024 | 08:02 AM
Racepres's Avatar
Racepres
No Timesert for me...I use threaded inserts from Fastenall...thin wall (close tolerance) usually...and No Odd Size tooling required!!!
Edit; Tho a helicoil would be just fine in this application!!! And... those are 5/16 fasteners!!
Old Jun 26, 2024 | 08:10 AM
jeeperjo's Avatar
jeeperjo
I had a time sert put in to the exhaust pipe hole in the read head because the original hole got wallered out. It looks real good. Thanks.
Old Jun 27, 2024 | 05:10 PM
Scheebs's Avatar
Scheebs
Time-serts were invented about 5 minutes after the aluminum head was introduced!
Old Jun 27, 2024 | 05:59 PM
Hoginedgewood's Avatar
Hoginedgewood
Is that not an interference thread?
Old Jun 27, 2024 | 08:22 PM
Racepres's Avatar
Racepres
Originally??? Yes... Hard to do with any insert!! That ship has sailed!!
by asshats who invented their Own Thread spec... yet people still expound their Virtues... Give me an insert that uses readily available thread pitches and taps!!! I have that **** on the Bench!!!!
Helicoil gets a Pass....no need to go bigger than necessary...and not Over Priced!!!!
Old Jun 27, 2024 | 08:32 PM
ShovelEd's Avatar
ShovelEd
This is why I changed from bolts to studs.
https://secure.vulcanworks.net/store...t-S-and-S.html
Note:
Stock Harley heads, and S&S heads use different thread sizes. 😉
Old Jun 27, 2024 | 09:23 PM
Uncle Larry
Never had a bad experience with a Timesert ... Worked every time flawlessly
Old Jun 28, 2024 | 09:46 AM
jeeperjo's Avatar
jeeperjo
They needed them.
