You have to be careful when buying on Amazon. If the item is not being purchased from the manufacturer, there is no telling where the part you get is made. Most Bosch relays I've seen on Amazon are shipped from different companies and made in many different countries. If you go that route, be sure it's returnable.
I purchased some Timken bearings and the seller was Timken. The pictures of the bearings showed the part number and "USA" on the bearings so I purchased them. When they arrived, they were in the orange and black boxes and the bearings did have USA.
would you have a part number for what i need. im having trouble finding a bosch one here in au. also have you heard of volt flow high capacity relay brand ? they sell for $13
I think Echlin ECH MC23013..is NAPA one...However, I do Not know where made.. I did Find that the Bosch is available However...Made in Portugal..Good? Bad? Indifferent???
Repco or Supercheap should have Hella, never had a problem with a relay from either of those stores.
