Starter Kill Switch
Old Sep 15, 2024 | 11:21 PM
sbrmike's Avatar
sbrmike
Default Starter Kill Switch
I don't know what you would call it much less a source, so I think I want to put one on my 1984 FXE. This is one of those switches that goes on the Negative battery cable. I would appreciate a few options (styles) and sources. I will try and mount it somewhat hidden but very accessible.
Old Sep 15, 2024 | 11:41 PM
Spanners39's Avatar
Spanners39
Best place to start looking is a marine supplies place, most boats have a battery isolator switch. Because of the job they do, they tend not to be very small.
Old Sep 16, 2024 | 05:52 AM
chopper_man's Avatar
chopper_man
Kill switch should should not go on a battery cable, much too high an amperage. Kill switch could go pretty much anywhere on the control side. Think starter solenoid, inline with starter switch, etc. Best place in my opinion is the positive feed of the ignition coil as it will also prevent push starting of the bike as well.
Old Sep 16, 2024 | 08:02 AM
Joe12RK's Avatar
Joe12RK
kill switch is a misleading term. you are looking for a battery disconnect. I suggest a panel mounted one, not attached to the battery like cars and boats.
Old Sep 16, 2024 | 08:07 AM
Racepres's Avatar
Racepres
Or your RV center
Misnomer.
There is a Reason I tend to Harp about Terminology....Perfect example Sometimes just a Bit of Research is in Order!
Yes
Old Sep 16, 2024 | 09:23 AM
Ytcoinshooter's Avatar
Ytcoinshooter
Default My post Kill Bill is about the Bates battery disconnect.
What you’re looking for is what my post is about. Quality part.
Old Sep 16, 2024 | 09:27 AM
Racepres's Avatar
Racepres
Who would Know...I thought it was a Movie Review!!!
Old Sep 16, 2024 | 01:03 PM
Ytcoinshooter
Very true! I got a laugh - thanks.
Old Sep 16, 2024 | 08:11 PM
sbrmike's Avatar
sbrmike
Thanks. I need a battery disconnect switch. I said in the initial post that I didn't know what it was called. I am very rural. It is going to be a chore to source one locally. At least I have a name and two logical locations to search, i.e. Boats and RV's.
Old Sep 16, 2024 | 08:56 PM
Ytcoinshooter
I ordered mine from low brow customs. Bates product - made in Germany, it’s a quality piece.
