Best Carb for a 66 Sportster
Old Jun 2, 2025 | 11:04 AM
slaphappytoys's Avatar
slaphappytoys
Stage IV
Question Best Carb for a 66 Sportster
Hello,
I just purchased a 66 Sportster and it has an old Tillotson on it and want to replace it. I contacted S&S and they said they do not have one that will fir because of the magneto. What are my choices, clean and rebuild the old? It has a 1 cable throttle, so might have to switch to 2 cable. Thoughts?
Old Jun 2, 2025 | 11:17 AM
Racepres's Avatar
Racepres
Originally Posted by slaphappytoys
Hello,
My Bet is...you need to post this in the Ironhead Section... I do Not recall what I used on My '65 IronHead...but, Betting it was a Zenith/Bendix..IMHO the very best Carb for an IronHead... In Fact My '77 Ironhead, will do an Honest Ton inside a Quarter mile, with the Zenith/Bendix.
When you want to experiment..the original Lectron, a Round Slide Mikuni, even a Ka-Sneeze, is Better than most, except the Bendix!!!
Old Jun 2, 2025 | 05:46 PM
magnum45pete's Avatar
magnum45pete
Bendix on one of those Ironheads,...
Never go duel cables,....
that was only ever to meet fed regulations later, as they didn't trust you to close the throttle if ya crashed !!!,....
all they do is make things harder and more expensive to get to work,... a single cables usually silky smooth in opperation
Old Jun 3, 2025 | 04:39 AM
Trumpet's Avatar
Trumpet
@slaphappytoys call Jr at Burkes V-Twin LLC in Tiverton. He's doing a lot of vintage iron. Solid guy, solid answers.
Old Jun 13, 2025 | 08:27 AM
66 FL's Avatar
66 FL
I had a Bendix carb. on my '69 Sportster. I also bought the adjustable main jet and my bike ran beautifully. If you get a carb without an adjustable main jet you will need a special tap 9/32x32 or you will render your carb junk.
Old Jun 13, 2025 | 09:09 AM
Racepres's Avatar
Racepres
An Adjustable main jet is Most Certainly Not the preference.. Most have No Clue how to Use the damn Thing!!
I personally dislike them..If you need to Fool with yer Carb to that extent...You have Other Problems..
Old Jun 15, 2025 | 09:07 PM
Scottmont's Avatar
Scottmont
Stage I
I have one of those! The best move I ever made with her was to replace the Bendix it had when I got it to a .38mm Mikuni round slide.. now to be fair the reason I bought the Mikuni was I was at my witts end trying to make her a reliable.starter...every time ..without the usual cursing and kicking and screaming..and possible laughter from folks close by...at my old *** trying to kick start a bike as old as me! Turns out after enough time learning and just trial and error my INTAKE manifold was the issue. If you have a leak at the intake you will NEVER get the bike to start and indeed run well or reliably...
Old Jun 16, 2025 | 07:15 AM
66 FL's Avatar
66 FL
Why would you say that???
Bass Player's Avatar
Bass Player
No picture?
Old Jun 16, 2025 | 07:34 AM
Racepres's Avatar
Racepres
Give anyone I know an Adjustment, and they Will Adjust... and it will Never be the same..gotta do it all again... I tell em...don't bring it to me if you Touched it!! Some simply cant resist insisting they are Master Tuners!!!
