Shovelhead cone/generator frame question
Old Jul 11, 2025 | 10:43 AM
Ftwkm's Avatar
Ftwkm
Default Shovelhead cone/generator frame question
Will a shovel head generator motor fit in a shovel head cone frame?
Old Jul 11, 2025 | 11:23 AM
hellonewman's Avatar
hellonewman
yes it will
Old Jul 14, 2025 | 06:22 AM
1981 suprglide's Avatar
1981 suprglide
oh yeah, the pan-shovel will fit right in there
Old Jul 14, 2025 | 07:28 AM
Racepres's Avatar
Racepres
^^^ And... a Pan-shovel is Not a Generator Bottom Shovel...Two entirely Different Things.. H-D Never produced a Pan-Shovel!!
Old Jul 14, 2025 | 03:39 PM
1981 suprglide
say what I beg to differ it's the same bottom on a pan head
Old Jul 14, 2025 | 04:17 PM
hellonewman
Its different visually for starters then in how the timer mounts and the provisions to control it vs a shovel setup. Also oiling to the lifters if at all vs a shovel, oil return arrangement and whether its inside or outside oiler. Most pans were inside oilers but shovels are not. The Pan-shovel designation is for someone that really wishes they had pan heads on it but want the recognition anyway.
Old Jul 14, 2025 | 08:11 PM
Racepres's Avatar
Racepres
Actually..Pan-Shovel is for Them cats that had a Pan and thought the Shovel heads were a bit Better..(not worth it to Me)..More like a Shovster to Me...But..There were quite a few Done..
Do Not fall for the old "same bottom end" internet BS...Kinda like a Evo cannot, no way, have a Shovel Bottom End..Not Possible!!
Unless you go with the Shovel Jug mounting and Steel Cylinders..No Longer either to me..Now it is a Drag Racing Engine tho!!
BTW Evo's Do sound at least as good as a Shovel, when equipped with Steel cylinders!!
Old Jul 14, 2025 | 08:24 PM
hellonewman
I know it was a thing and why but times have changed. Now it's more impressive to have a Panhead so they need to let you know what it once was.
tbonetony06
Dec 24, 2024 08:00 AM
fiveola
Flathead
Jul 6, 2023 06:14 AM
citytrucker26
Aug 20, 2010 11:58 PM
sawdust
Jun 30, 2007 04:04 PM
Hilli
Feb 25, 2007 03:43 PM
