Went from starting very well no nothing now. Points look good and I will check with a feeler gauge. No broken wires, good battery, good plugs, new switch etc. I ground a plug to the head and there is no spark.
I assume the only two things are the condenser or coil? Both parts are in excess of 25 years old and have been sitting that long. Any way to test either part before I buy new and throw parts at it?
Make sure you have 12v power to the coil. with an Ohm meter measure the resistance of the primary side of the coil, should be 4.8-5.0 ohm's. Secondary should be around 10k ohm's.. If both of those are good replace the condenser..
Here's a video I mad a long time ago to test the coil, wires and plugs..
Take the condenser Out..then try for Spark..tho I have Never had a Condenser go bad via Shorted..I guess it is Possible.. bad condensers generally let the bike start and Idle..but, No Acceleration at all!!!
My Bet is points are Not clean and/or adjusted,.. especially if been sitting...not came on suddenly...which is probably something else..like possibly failed coil
Any suggestions on brand of electric ignition? Any idea on cost? My bike is far from OEM wiring is my main concern. Then having to fight and re time the motor.
