Alignment tools
Old Dec 28, 2025 | 11:56 AM
chizzler's Avatar
chizzler
Default Alignment tools
I know they make oil pump and tappet block alignment tools but I think maybe they're for later engines? I'm pretty sure I'm going to be blocking the oil ports in the tappet blocks for the S&S solid lifter conversion and I don't see anything in the manual about needing one for the oil pump, what do you guys say? The only thing I could think of is maybe needing one for the tappet blocks to make sure the rollers track straight on the cam, but not sure if there's anything I might be missing. Thanks.
Old Dec 28, 2025 | 06:54 PM
misfitJason's Avatar
misfitJason
The lifter block and oil pump alignment tools work. However they are for lifter block alignment on pre-Twincam. They align the oil pump on Twincam motors and rocker boxes
Old Dec 28, 2025 | 08:31 PM
chizzler's Avatar
chizzler
So I don't need to align the oil pump on the shovel but I should use it for the lifter blocks? I'm trying get away without buying any more tools if I can.
Old Dec 29, 2025 | 03:09 PM
TwiZted Biker's Avatar
TwiZted Biker
All the lifter block tool is a tall taped bolt, early blocks were self aligned with countersunk screws, you can use one of those on the later blocks to do the same as the fancy tool. Frankly there’s so little play in the lifter blocks outside dialing in a ***** out track engine they align damned true without getting fussy.
Oil pump the top two studs do the aligning needed, just take a bit of care torquing the cover properly and using the correct gaskets for the pump.
Old Dec 29, 2025 | 08:15 PM
chizzler's Avatar
chizzler
Thanks for the reply. The book says to align them within .0005" of the scribed lines. I can only make out vague lines for the front tappet block and that measurement is ridiculous. How the hell would you even measure that? Ken sent me a link for 4 of the tapered bolts for 8 bucks so I went for it. They'll be coming from New Jersey so I should get them quick. I'm just hoping they don't smell too bad My oil pump doesn't have studs. It's all bolts. I still don't have my cylinders yet but I'm trying to get as much of it together as I can. I'd like to get the engine and tranny back in the bike and then I'll do the top end when I get the cylinders back.
Tommy B
Twin Cam Motors
11
Apr 23, 2024 03:29 PM
Scarlet85FXST
Mar 22, 2023 02:29 PM
Lammy1000
Milwaukee Eight (M8)
Nov 1, 2022 11:28 PM
Lunchboxx
Engine Mechanical Topics
26
Oct 19, 2016 11:03 AM
hdfatboy54
Exhaust System Topics
28
Nov 25, 2007 07:25 PM
