BTW, The ground connection on a regulator does not take dumped over-current to ground. The ground provides a current path for charging and voltage reference. The regulator either opens or shorts the output stator windings to regulate current.
If it dumped current to ground it would short out the battery. You need a circuit (circular current path) for current to flow.
Man this brings back memories. I put an Accel rectifier on my 76 FLH almost thirty years ago and it's still working good. I did it in the parking lot of a local shop that's long since been gone. If I had to do it again I'm sure I'd be scratching my head. Good to hear about Cycle Electric, I don't know if they were around back then or not.
Oddly...I was Taught ..Years ago
A Harley Alternator puts out 100% continuously..the Regulator shunts off Excess basically to Ground..Not being an Electronics Engineer...I believed them...and did Find, that if Not Grounded...the Battery will get Over Charged..Try It!!
A Harley Alternator puts out 100% continuously..the Regulator siphons off Excess basically to Ground..Not being an Electronics Engineer...I believed them...and did Find, that if Not Grounded...the Battery will get Over Charged..Try It!!
Well It's not correct. To short somthing to ground you need a loop for current to flow..
I'm not going to try disconnecting the ground on a regulator. Good chance it damages the regulator then over voltages..
Wow, you gentlemen have given me plenty to consider. I suppose it I was just going with the OEM parts there wouldnt be much of an issue. But since the CE kit is similar to the EVO charging system 32-38 amps I will attach the ground wire to frame or transmission plate, put a 30 amp fuse in-line to positive battery terminal as suggested by CE.
A cautionary note if the CE regulator is the big heavy one, check the factory mount close for any cracking before installing that monster. I had to make a heavier mount that goes off the front motor mount for the current bike build. That CE reg is 3x the weight of the stock one.
No One said "Short to ground"...I said "Shunt Excess to Ground"... which is , to my Understanding, How the Shovelhead (Evo too) voltage regulator Works
