ok so...head gasket fixed..............
Old May 29, 2008 | 06:55 PM
82flh's Avatar
82flh
Default ok so...head gasket fixed..............
put one half gas tank on fired it up good as new
now...........
how long should i run the bike before retorqing?
10 minutes or so?
how often should i retorque these heads?
i just used the cardboard teflon coated one cause i didnt feel like ripping into the other cylinder
to dam nice out
i tightened up front head
so...little help guys?
im baaack........!
Old May 29, 2008 | 11:47 PM
megawatt's Avatar
megawatt
Default RE: ok so...head gasket fixed..............
82flh,
Get it up to operating temp, then retorque 'em.
In the past I only retorqued them once. I suppose it wouldn't hurt to do it twice but I never had problems just doing it once.
Old May 30, 2008 | 05:16 AM
82flh's Avatar
82flh
did you use the cardboard teflon coated gaskets?
because i know its much easier with the blue teflon but i didnt have the cash
Old May 30, 2008 | 06:22 AM
megawatt's Avatar
megawatt
Yes, I used the blue teflon coated paper gaskets.
Old May 30, 2008 | 07:32 AM
Rodney's Avatar
Rodney
Glad to hear you up and running![8D]
Once I re torque after the first test ride I will put a wrench on the head bolts and every other bolt I can reach one more time after several hundred miles then anytime after that if and when I doing any other work on the engine that gives me access to the bolts. IE when I have the air cleaner and base off, coil out of the way ect.
Old May 30, 2008 | 05:18 PM
82flh's Avatar
82flh
operating temperature
like 5 minutes or so? before torquing?
dam if thats the case
im surprised i lasted 25 miles before she blew
Old May 30, 2008 | 05:24 PM
82flh's Avatar
82flh
Default in case your all wondering heres my ride
here ya go
[IMG]local://upfiles/48181/C0CA9D2DC74A411785320647BD3F36CC.jpg[/IMG]
Old May 30, 2008 | 07:09 PM
megawatt's Avatar
megawatt
Default RE: in case your all wondering heres my ride
Man, that is one shiny motorcycle...beautiful bike. Timewise, I can't say how long it takes to get up to operating temp. Just get it fully warmed up and then, retorque. Like Rodney says, checking the head bolts when you are doing other maintenance that allows you access couldn't hurt.
Too late now if ya didn't but, did you check the head and cylinder surfaces for flatness while the heads were off?
I hope your head gasket troubles are behind you.
Old May 30, 2008 | 07:30 PM
82flh's Avatar
82flh
i didnt guage the surfaces but when head gasket blew i imediatly pulled over and shut it down
so i didnt run it hot
also if you look at rear exhaust (one that crosses over to other side
pipe didnt even blue so no excess heat should mean head didnt warp
i know for sure its casue i didnt retorque
was to dam nice out last week on that day
lol
laziness comes with a price i guess
95 Ultra
EVO
Nov 12, 2012 10:00 PM
stlboarder
Dec 23, 2010 10:46 PM
cbaker1@farmersagent.com
Exhaust System Topics
11
Aug 31, 2010 08:39 AM
straydog13
Ironhead
Aug 19, 2008 09:44 AM
fj4069
Nov 4, 2007 11:48 AM
