revised plee for help
Old Jul 8, 2008 | 04:36 PM
cady1's Avatar
cady1
2nd Gear
Default revised plee for help
Hello everyone Im in desperate need of your help Im supposed to leave this thursday morning for bike week in getysburg. My distributor was lifted up about 5 inches an then put back down so my timing is way out. I have no idea where any timing marks are and I am working on the bike right now If you can help me with some info please call me.let the phone ring twice and I will call you right back we have caller id and free long distance. please help if you can, dont assume someone else will call.Its 5:30 pm est. I'll be working on the bike until 9pm. Please call.&nbsp\\; 1-607-324-0648[align=right][/align]
&nbsp\\;
Old Jul 8, 2008 | 09:58 PM
markymark02's Avatar
markymark02
Default RE: revised plee for help
I was curious if you had any luck, hit me up when you get a chance, Mark
Old Jul 8, 2008 | 10:55 PM
FilthyLucre's Avatar
FilthyLucre
Too late to call.&nbsp\\; It is fairly simple to get it back in the right place.&nbsp\\; Pull the plugs and rotate the engine until the front cylinder advance timing mark is visible in the timing inspection hole.&nbsp\\; This is the straight line.&nbsp\\;&nbsp\\; Look at the top of your distributor.&nbsp\\; If it is stock the distributor cam should have a line on it.&nbsp\\;&nbsp\\; Line it up with the rubbing block.&nbsp\\; With the wire toward the rear of the engine lower the distributor down.&nbsp\\; Look at the mark on the distributor cam and see how close it is the the fiber block on the points (the part that rides on the distributor cam)&nbsp\\; If they don't line up lift it again and shift the cam in the right direction one tooth and lower it again.&nbsp\\; Try to get them to line up.&nbsp\\; Chances are it won't line up 100% but get it as close as you can.&nbsp\\; Reinstall the stem clamp and tighten it down.
&nbsp\\;
Time the bike by setting the point gap at .020,&nbsp\\; the line in the inspection window.&nbsp\\; With your test light connected and the cam held in full advance and the base loosened, rotate the base until the light just flickers when the points break.&nbsp\\; Tighten everything down.&nbsp\\; You should be good to go.&nbsp\\; You can check it with a strobe running at 2000 rpm but it will be right.
Old Jul 9, 2008 | 12:24 PM
Rodney's Avatar
Rodney
I talked with him last night and sounds like he's got it running!
some fine tuning on the S&amp\\;S may me needed.
Rusty Axle
Shovelhead
31
Jun 25, 2023 10:42 AM
doc308
Shovelhead
28
Jul 24, 2018 06:27 AM
langwilliams
EVO
61
Nov 11, 2015 10:18 PM
bigspyke
Aug 4, 2012 08:36 AM
riden2low
EVO
11
Mar 29, 2007 05:48 PM
