Intake question?
Old Oct 12, 2008 | 05:54 PM
slowinhavasu's Avatar
slowinhavasu
Stage IV
Default Intake question?
I'm running a 68 shovel ,big stroker,S&S shorty. Should I run the o-ring intake or the flat gasket kit ??? Anybody run the two piece VS the stock style clamp ??? Thanks....c
Old Oct 12, 2008 | 07:12 PM
sqdealgeorge's Avatar
sqdealgeorge
I've run both systems Just make sure you support the carb air filter off the front shovel
Old Oct 13, 2008 | 08:30 PM
slowinhavasu
Stage IV
Did you find one to be better then the other ???? Thanks for the reply....
Old Oct 14, 2008 | 12:41 PM
AlCherry's Avatar
AlCherry
I found the wide rubber gasket to be easier to deal with. I also coated it with the red high heat RTV for a better seal. Just let it sit overnight for cure time. Sqdealgeorge is REALLY right about mounting the carb to the front valve cover. That cures alot of problems. Your S&S should have come with the bracket.
Old Oct 14, 2008 | 07:52 PM
Tim Garry's Avatar
Tim Garry
I concur on the usage of the braket, even if it does not look as cool. Go with what works
1Sparks
Shovelhead
Apr 6, 2019 06:36 PM
EricSmith
Jun 5, 2018 02:32 PM
USKEW
Shovelhead
Feb 14, 2018 09:47 AM
Protz027
Jun 27, 2012 07:45 AM
hddave2
Mar 19, 2008 06:10 AM
