Controls and floorboards
Old Sep 6, 2009 | 07:44 AM
jeffwoods1962's Avatar
jeffwoods1962
Default Controls and floorboards
I can't find my answer, I'd like to find a set of controls with floorboards that will adapt to my 79 shovel fx frame, Any Ideas???
Thanx
Jeff
Old Sep 6, 2009 | 07:08 PM
pococj's Avatar
pococj
There are none that are "bolt-on" because you are missing a tab on the frame on the right, and a tab on the primary on the left. That said, you can use a set of forward controls and there is a set of floorboards that mount where the pegs would mount. These are adjustable and I know J&P carries them.
Old Sep 7, 2009 | 12:02 AM
FilthyLucre's Avatar
FilthyLucre
Quickest way to deal with the missing floor board tab on the right side is either buy the weld on piece or use a 3 piece clamp. The left side will require replacing the outer primary cover with an FLH type. After you dealt with the that you can just use FLH brake and shifter parts.
coasti1079
Shovelhead
Apr 9, 2018 09:58 AM
lucky23
Shovelhead
Feb 20, 2017 07:39 AM
YeOldeStonecat
Shovelhead
Jun 10, 2013 09:48 AM
Shannigans
Apr 24, 2010 02:30 AM
wrockisland
Shovelhead
Mar 7, 2008 06:33 PM
