1966 FL-Ape Hanger Install
Old Nov 28, 2009 | 08:05 PM
hunter66's Avatar
hunter66
Stage II
Default 1966 FL-Ape Hanger Install
I have a 66 FL. I want to put 16" apes on it. My current bars are split. To install do I cut my new bars in the center? They do have Knurls about 3"s apart. The bar clamp will not be able to be spread large enough for the new bars to be threaded through the openings.
Old Nov 29, 2009 | 12:16 PM
FilthyLucre's Avatar
FilthyLucre
Do not cut the bars, with the apes you will have too much leverage on them and they will not stay in place, especially without knurling. Buy a set of 74 and later FX risers. These were made for one piece bars and will fit your top bracket.
Old Nov 29, 2009 | 12:31 PM
hunter66's Avatar
hunter66
Stage II
FilthyLucre, Thanks for the advise. Will the FX risers fit under the original
bar clamp chrome cover?
Old Nov 29, 2009 | 11:47 PM
FilthyLucre
The stock FX ones will not. I've seen some modified after market sets that would. The problem is they are a little higher than the stock FL riser.
Old Dec 6, 2009 | 01:49 PM
RUBKILLA's Avatar
RUBKILLA
1st Gear
a 2 piece stock riser set up will fit under the triangle cover..........ive got 18s on my fl........and yea, dont cut em'
Old Dec 6, 2009 | 03:07 PM
sqdealgeorge's Avatar
sqdealgeorge
Plus 1 on Rubkilla info
Matt K
Oct 19, 2013 08:57 AM
jeffreyjames
Jul 12, 2011 05:52 PM
ZeroFiveFour
Mar 11, 2011 09:22 AM
Mark98012
Nov 25, 2008 12:47 PM
BlessedHellride
General Topics/Tech Tips
11
Jun 4, 2007 05:56 AM
